Question about Polaroid PDM-0711
Pdm-2727 portable dvd player
Player comes on but will not play, on the screen it has loading disk and i can hear the disk turning.what you think? Get bad disc reading
    President:
  • 357 Answers
Hi there
I think your DVD Player could have been damaged while it was in storage, this sounds like there is a problem with the lens (laser), i am going to suggest that you take it to a repairman and ask him to fix it or buy a new laser for your DVD Player attempt to fix it yourself.
If your DVD player is still under warranty, you should take it back to the retailer and have it repaired or refunded.
This could also be caused by "un-married" Player and Disc, if you bought the DVD Player in one country and bought the DVD's in a different country, this could also cause the problem. If the DVD's are copied, that could also cause it.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as pdm-2727 portable dvd player - 5692f33.png if it helped you.
Kind regards
Dustin Ellse(BearWeb)
Posted on Jul 03, 2008
    Brigadier General:
  • 6,966 Answers
Often this is indicative of either a dirty disc (unlikely if you tried several) or a dirty or weak laser optics. The easiest user action possible is to clean the "eye" using cotton buds. It might help to likewise clean the inside (or at least what ever is reachable/exposed) with a can of compressed air. Additional lubrication wherever applicable. Alternately, a CD cleaning disc may also be used similar to those used for CD ROMs of PCs which are normally/readily available from most computers shops/stores.
Of course should cleaning fail, it may be time for replacement of the optics or considering cost, the entire unit. Sorry
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa..
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Player comes on but will not play, on the screen it has loading disk and then goes to no disk
That means the disk is corrupted. Please make sure that data is burnt properly to the disk.
Jul 08, 2009 | Polaroid PDM-0711
Bad disk error no matter what disk is played.
try a cotton swab and len cleaner. rub a small amount on the laser eye and then dry it off. do thus several times. be careful and don't put to much on the cotton swab. it don't take alot
May 01, 2009 | Televison & Video
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Can't find the parts I need
Hey, not sure if you still need it, but there's a power cord for the PDM-2727 listed in an Ebay auction. Like you, I need the AV cord, er, at least I think that's the problem. The listing also shows an AV cord available for an extra $5 but it looks generic. Might be compatible though. I don't need the power cord or I'd ask the seller, but you might want to check it out if you still haven't found power cord/AV cable yet.
Mar 02, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Check out my other post here:
www.fixya.com/support/t259278-emerson_pde_2725n_dvd_player
Dec 19, 2007 | Car Audio & Video
NEED REPAIRS ON DVD PLAYER
polaroid dvd pdm-0722 it playes but no picture if you push the button near the screen it will come on for a second but the picture is also upside down can you help thanks this player is not used that much no kids thanks
e-mail is corv1990@eatel.net
Sep 02, 2007 | Polaroid PDM-0824 Portable DVD Player
Polaroid PDM-0711 Logo
173 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
