Question about Sony VAIO GRT260 Notebook
Dell Laptop WiFi Connection
I have a dell inspirion 6000 laptop. Im in the military deployed overseas. The router that i connect to is a public router that all military members use. I have had no problems for the past 5 months but as of 3 days ago anytime that i connect all i get is "Limited or no Connectivity". All of the other users are able to connect with no problems. My signal strength is excellent. I've tried to rollback to my previous settings of a week ago and also tried the repair function of the Integrated ProSet Wireless under the control panel but neither worked. Any ideas??
  • 2 more comments
  • LiveDakota Jul 03, 2008
    It is windows XP. Also i just looked and not sure if this could be the problem but the IP address and default gateway are exactly the same. All settings are set to automatic for obtaining the IP address.
    It is ticked. I have tried that already with no change. Any other ideas?
    You are correct, there are no security settings for the network that i am trying to connect to. There is a "Logon" that is required once you are connected and open your browser window. As far as settings, i compared mine with a friend that was connected and they are the same....with different IP address of course.
    With the address' that the router assigns, if the IP and Gateway are the same, could that cause this problem? That was the only difference i could see in my settings and the other computer....his two address' were different.
  • Dave May 11, 2010
    are you running XP or VISTA
    Sergeant:
  • 287 Answers
Right click on the WiFi icon on the taskbar, select "view available wireless networks".
Then right click on change order of preferred networks
If the "Use windows to configure my wireless" is unticked, tick it
From the list below select the network you are trying to connect to and remove it and press OK
Then right click on the WiFi icon again and Vioew available networks and try to connect
Posted on Jul 03, 2008
  • 2 more comments
  • Dave Jul 03, 2008
    ok then try this
    From the list below select the network you are trying to connect to and press "properties"
    I assume the connection has no security but perhaps it does ??
    I would expect that if the n/w you are connecting to has no security (public) then the authentication will be OPEN and the data encription will be disabled but perhaps not
    Also try ticking the "connect even if the network is not broadcasting"
    If possible compare these settings to a system that is working and make any changes required
  • Dave Jul 03, 2008
    also on the "connection" tab make sure the "connect when the network is in range" is ticked
  • Dave Jul 03, 2008
    Yes I think the IP's should be different. Is your "gateway" IP the same as the other PC?
    Try disabling the wifi card and re enabling it
    "Start, Settings, Network connections"
    Then right click on the wifi icon and disable it. then reboot PC and enable the wifi again
  • Scott Mar 29, 2012
    on mine the Gateway and the,DHCP settings are the same,
    If you did this ,Then right click on the wifi icon and disable it. then reboot PC and enable the wifi again,,,,you may have to get an Ethernet Wire and hard wire it directly to the router and the laptop ,,make sure you can connect with it hard wired first ,,than enable wireless and try to connect wireless..
My Dell laptop will only connect to public WiFi with limited connectivity
Follow the following steps to resolve Wifi issues on your Laptop. Open Control Panel - Select Network and Sharing Center - Manage Wireless Networks - Highlight your Wifi Network - Right Click and Remove. Reset the TCP/IP stack of the windows system with limited connection status.
My laptop is showing limited Internet access over my home WiFi - Quora
https://www.quora.com/My-laptop-is-showing-limited-Internet-access-over-my-home-W...
Nov 13, 2016 | Dell Computers & Internet
Dell inspiron 600 laptop stopped connecting to the
Hi, I think from you question your Wifi is TURNED OFF. if it is a Toshiba there is a switch on the front edge. if its a Dell there is a switch by the start button. Check to see that YOUR Wifi is turned on and active.
Take care
Jul 21, 2010 | Dell Inspiron 6000 Notebook
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
What do i need to do to connect to the internet wireless with a dell inspirion 1000 24 hours
If your laptop does not have an internal wireless card you have options. You can get a usb adapter or get a car slot wireless adapter. Of course then you need a source for connection. You can pick up a high speed connection from verizon that works just about anywhere. Please give me a good rating. It means a lot to me. If you have any more questions please feel free to ask.
Jul 04, 2009 | Dell Inspiron 6000 Notebook
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
Vertical lines on lower third of dispay on Dell Inspirion 6000
bad lcd or video cable is not making good connection or is bad
Apr 10, 2009 | Dell INSPIRON 6000 CENTRINO...
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Can't connect to wireless.
You should download latest wireless driver from http://support.euro.dell.com/support/downloads
Dec 09, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
WIRELESS CONNECTION.
First you need to purchase or aquire a wireless router which can send out a wireless signal. Be sure to bring you laptop to the store to ensure you hare busing a router which emitts te right frequecy.
for example, there are laptops whihc have a 802.11b wiress adapter and thos which have a 802.11n whic only works on on a 802.11 n frequency, so please be sure to check with the sales person.
Also, if you are goin withing 100 fee from the router for just in appartment or upstairs or down stairs you will not need a high end system. You may want a middile of the road option no more tha $75 for the router.
You would simply plug in the wireless router to the ethernet cable. It will come with software which would walk you though instructions on how to enable your wireless net card on you laptop and to detect and secure your wirteless router.
Hva e fun.
Kwame
Oct 05, 2008 | Computers & Internet
Sony VAIO GRT260 Notebook Logo
369 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
