I recently had a new outdoor unit installed on my central heat and air conditioning sytem. I have had the installer out 3 times and the system still does not operate correctly. Sometimes when it cycles (every other time or every third time) the unit does not blow cold air. Sometimes the unit comes on not blowing cold air and the compressor fan is running but not the compressor. Sometimes after 15 minutes of this the compressor will come on. What is the problem.
  • 104 Answers
It sounds like the compressor needs starting components installed on it. All a/c units have a run capacitor for the compressor and another one for the condenser fan motor. These motors use these capacitors all the time when the motor is running. However, in some cases, this capacitor isn't enough to get the compressor spinning initially. Starting components consist of two parts, a start capacitor and a potential relay. The starting components are wired in in series with the compressor run capacitor. When the compressor turns on, the start capacitor gives the compressor an extra "kick in the pants" to get it going, then as soon as the compressor is spinning, the potential relay disconnects the start capacitor from the circuit for the duration of the run time and resets when the compressor turns off. Most likely, your indoor unit has a thermal expansion valve (commonly known in the trade as a TXV). This valve maintains a somewhat substantial differential between the high side and low side of the compressor after the system turns off which can be difficult for the compressor to overcome without help. Right now the compressor is trying to come on, can't overcome the pressure, and is tripping it's internal overload to protect itself. Eventually, as the overload repeatedly trips and resets over and over, the compressor will finally get around to a position where it will start once in a while. I am not a gambling man and I would bet you money that this will solve your problem. If you would be so kind as to rate my solution "Fix-Ya".
Posted on Jul 03, 2008
Is there a system mismatch with an American Standard 13 seer 3 ton compressor and a Nordyne 3.5 ton air handler? Noise at TRV when heating.
This must be a heat pump? Sometimes the unit can be more efficient with this combonation. What you are probably hearing is the reverse direction of the
refrigerant going back through the liquid line.
If in cooling sometimes you can hear a gurgling sound going through the expansion valve, sometimes
this is a sign of low refrigerant or the system is fine..
If you recently had the outdoor unit replaced and noise is an issue, check to see if the unit has isolation pads installed underneath the unit whether
it be on concrete slab or on brackets mounted to
house. Sometimes the new units come with compressor that has a jacket installed over it
Feb 14, 2010 | Ruud Central System Air Conditioner
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
Sep 10, 2008 | Amana Heating & Cooling
Central Air Conditioning or Window Air Conditioner
Many people look into installing air conditioning in their home every year. There are many options to consider when it comes time to make that decision. To help make that decision more clear, I will explore some of the positives and negatives of the two major options. Ductless Split A/C type units lately are also becoming more of a popular option. I will do another “Tips and Tricks” on that option. To include that in this one would just be more confusing. So for now we will just look at window air conditioners and central air conditioning.
Central air conditioning is usually the best way to go if you already have a central hot air heating system already installed in your house or building. The advantage that you have is that you already have the air handler or blower part already installed. The ductwork for the distribution of the air is also all ready in place. The ductwork may need some modification to make it work well for air conditioning, but the major part of it should be adequate. To use the existing furnace and ductwork an A/C coil will need to be installed at the furnace. An outdoor condenser unit will be installed outside and copper tubing will be used to connect the coil to the outdoor unit. Some electrical wiring will need to be done to power the outdoor unit. Low voltage wiring will also be needed to hookup the thermostat, the furnace, and the outdoor unit together so that they can talk to each other. Basically the thermostat will just tell the furnace to run the blower on high speed and the outdoor condenser to start up.
If there is no central hot air heating, then the installation of central air conditioning can be much more difficult. Many homes that do not have hot air heat also do not have the room to install ductwork. This would eliminate this possibility. If you are in this category you should get a professional to look at your situation to see if central air conditioning can be done. If it is the room available is to enough to do a good job and get large enough ductwork installed, then do not force the issue and go another option. Ductless split type air conditioning may be your best option.
A window air conditioner in my opinion is a last resort for air conditioning your house or building. There are many down sides to window air conditioning units. There are two good things that window air conditioners have going for them. They are very inexpensive when it comes to cost per BTU of cooling. They also install very quickly and easily. That is where the good part of them ends.
Window air conditioners are security risks. If a thief wants to get into your house, the thin sheet metal box that holds the unit in the window can easily be pulled apart to get in through the window. I have seen many units that are not even screwed fast. If the window air conditioner is just there, balancing in the window frame, it becomes very inviting for a unexpected guest. The window air conditioner is also very inefficient. These units use more power per BTU of cooling than any other type of air conditioner. If you are a light sleeper, than chances are you will not want one of these window shakers. Window air conditioners are one of the loudest forms of air conditioning.
The fan for these units is very loud when running. Then add the noise of the compressor and you have enough decibels to keep many people wide awake all night long. If you choose to use a window air conditioner, than you should also look for a place that it can be secured and placed in a room that you will not be sleeping in.
As you can tell by now, I am not a big fan of window air conditioners. They do have a place for some people. However, you do need to be aware of the problems that you may encounter with them. The low initial cost can be offset by the fact that they typically do not last as long as a central air conditioner.
Central air conditioning will last much longer, be quieter during operation, be more efficient, be more secure, but the initial cost will be higher. How much depends on each situation. When considering your options for air conditioning installation you need to get prices for everything and then decide what type of unit will work the best for you.
on Jan 01, 2010 | Heating & Cooling
How Heat Pumps Work
How on earth can you get hot air or hot water from very cold outside air? How does a heat pump make this heat out of cold air?
When certain gases change their state from a liquid to a gas or from a gas to a liquid the magic happens.
A heat pump can do some pretty amazing things, when it comes to making heat. To understand the way they work, you must first understand what happens when certain gases change from a liquid state to a gas and back to a liquid again. To simplify it a bit we need to look at a basic air conditioning system. The refrigerant in an air conditioning system is changing to a liquid in the outdoor condenser. The compressor compresses the gas forming a hot gas. As this gas cools under high pressure it changes into a liquid form.
Inside the indoor coil the liquid is pushed through a small hole or orifice. When it comes out the other side it rapidly changes it’s state to a gas as the pressure suddenly drops. The rapid pressure drop changes the refrigerant to a very cold gas. Air flowing over the cold gas inside the pipes makes the air cool and provides air conditioning.
Now for a heat pump the process is much the same, only coils are just switched by used a reversing valve in the outdoor condenser unit. Instead of the heat being purged to the outside from the condenser unit, the indoor unit then becomes the condenser coil. The outdoor coil becomes the cold coil and cools the outside. This is why if it is very cold outside the unit will have to run in air conditioning mode for a short time to defrost the outside cold coil. When this happens the system will usually have electric heat inside to run and keep the indoor air warm.
The reality is that a heat pump is really no more than an air conditioner running in reverse. Through the magic of using refrigerants, a heat pump can then run many times more efficiently than straight electric heat. A careful heat loss/gain should always be performed by a qualified service person before any sizing of a unit. Too large or too small of a heat pump system can make it inefficient and possibly cause it to be very uncomfortable. The longevity of the unit can also be affected by sizing and installation. Be patient and look carefully for the best contractor to install your system.
A properly designed and installed heat pump system can give you many years of comfort and efficiency. If you look for and find the contractor that can do the job right you will get many trouble free comfortable years from your heat pump unit.
on Dec 29, 2009 | Heating & Cooling
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
When I turn the air on the heat strips comes on at the same time
Is this a central heat? From the size i assume it is.
You say air conditioning on part of your question then use heat pump on another part. So it is important for us both be on the same page.
With all due respect some people think they have a heat pump and it is just AC and electric heat also but is not a heat pump.
. If you have the outdoor AC unit running with your thermostat set for heat and the air coming off the out door unit is cold, or you see it "steam up outdoors" off the out door unit at times (we call this mode defrost).
If you actually have a Heat pump system some times it is wired to have the strips come on at the same time the heat pump comes on especially if you experience a lot of weather below 40' occasionally and have an emergency heat setting on your thermostat you most likely have a heat pump.
If you have a heat pump for sure now the heaters can come on with the outdoor section if
1 they are wired to do so or
2 the thermostat has 2 stage heating and the second stage is telling the elements to come on, or
3 the outdoor thermostat (if so equipped) is telling the elements to come on.
Any 1 or combination of these 3 items can cause the elements to come on wit the out door unit.
Mar 12, 2009 | Coleman Heating & Cooling
You can add Air Conditioning to Your Hot Air Furnace
Air Conditioning is easier to add to an existing central hot air heating system then you might think. Both systems use air to move the heating or cooling to the different parts of the house. With the addition of a coil and condenser to your system you can stay nice and cool all summer long.
The easiest way to add in cooling to a system is to install a coil on top of the furnace supply air plenum. This can be accomplished by cutting open the supply duct just on top of the furnace and sliding the air conditioning coil right in on the top of the furnace. The only limitation usually is the height of the plenum. If there is not enough height there, then the coil may need to be installed on a horizontal run.
If the horizontal run option is needed then you will have to make sure that all of the air flow goes through the run. If all of the air does not go through that run, then the ones that do not go through will not cool nearly as effectively as the rest of the runs that go through the coil.
After placing the coil in the ductwork, the piping and electric will need to be run to the outdoor condenser unit. After wiring and piping the unit the refrigeration lines will need to be purged, and vacuumed. This will clean the lines and take the air out of them. Any air in the system will cause the system not to work properly.
When all of this work is done you will be ready to have great cooling. The whole process usually takes me less than a day to complete. Adding cooling to an existing system is a simple operation when it is done by someone that has done it many times. If you have a hot air central heating system without the benefit of cooling, then you should check into adding the cooling feature to your system. You will be glad you did when the hot weather rolls back around again.
on Dec 08, 2009 | Heating & Cooling
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
272 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
