I believe you have a ground short in the main fuse wiring or at the main fuse location itself. Try locating it and as the suggested Tech from Firestone advised , replace the main fuse. frank
The second junction block (No. 2) is found under the hood on the forward part of the left wheelhouse (driver's side). The fuses, fusible links and relays in this junction block generally control the engine and major electrical systems on the car, such as headlights (separate fuses for left and right), air conditioning, horns, fuel injection, ECM, and fans.
The arrow is pointing to the headlight fuse.
