Question about Whirlpool Washing Machines
Water stays in drum - Whirlpool Washing Machines
    Novelist:
  • 161 Answers
Hose is kinked or pump is bad.
Posted on Jul 03, 2008
Detergent cup not draining
think you mean one compartment staying full of water this would be for softner or if the soap powder is staying in the drawer then a blocked pipe to the drum could clog useing to much powder at one time best results are put soap strait in the drum then cant clog i am an domestic engineere and have seen this problem a number of times
Aug 12, 2012 | Washing Machines
1. Laundry stays whet. some times there is water on the bottom of the drum after the machine finishes working. 2. while spining there is a constant fraction nois.
Check filter if it has one also clear pump make sure drain hose fully discharging water into waste/sink...Sounds like possible coin in pump or faulty drum bearings if drum is noisy when turning by hand........
Jun 14, 2011 | Washing Machines
Water stay in drum took drain hose off water still in drum
Probably sucked up a small sock or clothes in the water pump.
Apr 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water leaking into drum?
hi it sounds like you have a water valve staying open you will need to find out if it is the hot/cold then replace hope this helps
Mar 12, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
