If you do not have the disk you can use the links below to download the driver (copy and paste):
Setup and install HP Officejet 6310 All-in-One Printer:
http://www.google.com/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2FsetupCategory%3Flc%3Den%26cc%3Dus%26product%3D1119598%26dlc%3Den&ei=g7UwSqeOBYalsAbMmuHiBA&rct=j&q=HP+Officejet+6310+download+drr&usg=AFQjCNH2VkIqJB5qSW9stPAp_2jxjbzIMQ
Select your operating system HP Officejet 6310 All-in-One Printer:
http://www.google.com/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2FsoftwareCategory%3Fproduct%3D1119598%26lc%3Den%26cc%3Dus%26dlc%3Den&ei=g7UwSqeOBYalsAbMmuHiBA&rct=j&q=HP+Officejet+6310+download+drr&usg=AFQjCNFZYok6QLKOBao-JeCxcfscUuxklg
Or try:
http://www.google.com/webhp#hl=en&q=HP+Officejet+6310+download+drr&aq=f&oq=&aqi=&fp=9ZixuGkm6ts
you go on HP Officejet 6310 All-in-One printer, double click on it, a small window will appear, delete all recent commands
if problem not solve then turn off your pc and printer both and unplug the U.S.B cable, now turn on the pc and delete HP Officejet 6310 All-in-One driver and restart pc then install the driver manually again and print your documents again.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
display lights briefly then goes black and camera light by the USB port starts blinking
