Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
TV turned off and wont come back
TV lost picture and have loud vibration sound. No picture but lamp light is blinking as well as the television chimes randomly on and off. Vibration sound is constant while tv appears to attempt to shut off and then on again.
Have no control with tv on/off button or remote to stop this. Had to unplug it. Came back 2 hours later and as soon as I plig it in it starts the loud vibration noise all over again.
  • 1 more comment
  • AeroME Jul 26, 2008
    I have the same problem, where is the color wheel and is there any tricks to replacing it?
  • chriscolon1 Dec 20, 2008
    was watching tv and heard this loud noise like glass popping and then i turned off the tv and turn it back on and it made that same loud crashing noise. im going to see if its the color wheel as stated. if not im going to trash this tv and buy a lcd tv instead
  • jenglert149 Jan 30, 2009
    I have same problem and I even changed the Lamp (due to the three lights)
    Did not help
  • 49 Answers
Blingking lamp or led indicates failure in component loud vibration noise means overload or shorted component...check the horizontal output transistor...
Posted on Jul 03, 2008
  • 51 Answers
Looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
203 people viewed this question
Jerry Greenberg
Jerry Greenberg
