Question about KitchenAid Dryers
How to fix drive belt?? - KitchenAid Dryers
    Scholar:
  • 170 Answers
Take the front panel(s) off and it will allow you to take the top off. The belt runs from a little pulley at the bottom of the dryer around the top of the drum.
Posted on Jul 05, 2008
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
How to replace tensional drive belt
comment on what you call a tensional drive belt
Sep 22, 2015 | Cars & Trucks
Trot bilt tb280. Self propell ain't kickin in. Barely used. What could fix this ?
Check to see if drive belt is improperly installed.... Check to see if drive belt is worn or damaged.... Check for debris clogging belt drive.
Aug 29, 2014 | Garden
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
The drive belt keeps falling off, why? aand how do I fix it SHERRY
if the drive belt continues to come off it could be that the drive belt spring tensioner has failed.
Aug 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
DC30 Denon cassette deck Drive belt broken Are spares available? Are there instruction on how to replace drive belts?
Hi J,
Sorry no solution for you. But I was wondering if you managed to fix yours. My D-C30 just has the same issue. 10 seconds of clicking and reading on another thread it sounds like the drive belt is broken and needs fixing.
Did you manage to find any instructions or spares etc to do this?
cheers
Nick
Mar 23, 2010 | Denon D-C30 Shelf System
I have a Proform XP 550s and the belt skips/slips when you put any weight on it. Works perfect if you let it run without a body on it though. Any ideas on how to fix it? I've tried tightening and...
I would remove the hood first covering the motor (Usually 4-6 screws) so you can isolate the problem. Now you will be able to get a good look at what is going on underneath. If when you put weight on it the you see the motor keep spinning but the drive belt stop then you need a new one. You could temporarily tighten it until you replace it but it's probably ready to go. If the drive belt and front roller keep turning and the walking belt stops then replace the walking belt.
On mine I had to replace the drive belt and the walking belt. I went with the cheapest fix first (drive belt which was slipping) then I could still stall the walking belt but had no way of knowing that until I replaced the drive belt.
I guess if it's the motor you'll be able to tell that too by watching because it'll bog down.
Parts at TreadmillDoctor.com for me anyway. They have both online and by phone troubleshooting support.
Jan 25, 2010 | Exercise & Fitness
Error E005 in canon ir400s
reset cleaning belt /web roller counter
* (with head)
2 and 8 (simultaneously)
* (with head)
on lcd press COPIER>Counter>Misc.Fixweb press (C)lear button Fix web counter must be 0000000
Switch power off and on the machine
Jun 21, 2009 | Canon imageRUNNER 400S Copier
Main drive belt
The belt is old and has stretched.
Jan 12, 2008 | Seagate STT320000A Travan Tape Drive
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
