Question about Refrigerators
My refrigerator leaks water from inside opening on fridge ceiling. How do i fix?
    Genius:
  • 1,847 Answers
Check the video this will help you resolve your problem...
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Thanks for using Fixya.
Posted on Jul 03, 2008
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
Condensite on the ceiling in Whirlpool Gold top-mount refrigerator gb18dk
This sounds like a seal leak. Take a dollar bill and close the door with the dollar across the strip and pull. It will be loose where the leak is.
change the seal.
Dec 02, 2012 | Whirlpool Refrigerators
A lot of water leaking
You probably have a clogged drain line. Unplug the fridge for 24-48 hours with a towel by the drip pan for a simple fix.
Jan 22, 2012 | Kenmore Side by Side Refrigerator
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Water leaks inside refrigerator. what can i do?
Reattach the drain hose from the freezer to the fridge.
This is usually located under the plastic panel on the ceiling of the fridge.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking inside of the fridge from the top
It sounds like your frost-free freezer is cycling through its normal defrost mode, which allows the cooling assy. to be deiced and that melted ice (water) will run out and down to the drain in the bottom of your fridge.
Aduz
Mar 27, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
My whirlpool refrigerator is leaking water inside the refrigerator. i have no water or icemaker on mine. its just a regular old fridge about 9 years old. i keep it clean and vaccum out the bottom every...
Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Jan 06, 2009 | Refrigerators
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    Refrigerators Logo
    147 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
