Question about Car Audio & Video
I have Panasonic car amp model no. CY-SA 100 EU . I lost power distribution wire & diagrame for this amp. Please if some one can tell me how to power & ground &key on power for this amp this will be very helpful for me thanks.
SOURCE: Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Posted on Dec 06, 2007
devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
  • 92 Answers
SOURCE: I'm trying to wire up
White is front right, front left should be gray, left rear is green and right rear is violet. The yellow wire should be a constant 12V, red switched 12V(on when key is on). Black to ground. You've likely figured some of that out already. If you need more info let me know.
Posted on Oct 10, 2008
  • 1114 Answers
SOURCE: when my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Posted on Aug 20, 2009
kingbrizzle
  • 407 Answers
SOURCE: lost wiring diagram for sony
Red=Power (from radio fuse)
Yellow= Constant Power (battery)
Black= Ground
Blue= Remote (power antenna)
The speakers are a little foggy to me (sorry), but I do know fronts and backs, just not 100% on left and right.
Purple/Purple and Black= Right Rear
Green/Green and Black= Left Rear
White/White and Black= Left Front
Grey/Grey and White= Right Front
Hope this helps!
Posted on Aug 05, 2010
1999 4.7l jeep grand cherokee wiring diagram for the power distribution box
what kind of diagram the FSM has like 100 pages there.
just fuse names
just there loctions
or what each fuse does (a schematic only tells that)
and is posted now 100+ times here, ever search.
here it is 1 more time.
click wj
click wiring, bingo
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
its free, why not just look first?
Oct 24, 2015 | 1999 Jeep Grand Cherokee
Is there a diagram for a 98 Camaro z28 fuse box
Go to www.bbbind.com free wiring diagrams & TSB'S & power distribution -fuse / relay box's ! On home page click on technical information , next , five box's will pop open ,click on All TSB's and diagrams for every make and model - FREE , next page at the bottom click I agree . Then next page click on wiring diagrams , Then add you vehicle info - year-make - model , engine - then system - electrical distribution - subsystem - fuse panel !
Jul 25, 2015 | Cars & Trucks
05 Neon 30 amp starter circuit
The ignition switch . Free wiring diagrams here http://www.bbbind.com/.htmlfree_tsb Enter vehicle info. year , make , model an engine size . Under system click on electrical distribution ,then under subsystem click on power distribution .
Jul 18, 2017 | 2005 Dodge Neon
How wire two subs into 1000 watt rockford amp to get as much low power possible
to get lows will depend on the type of subs and sub box enclosure
Sep 11, 2010 | Panasonic CY-PA4003U Car Amp
I need wire diagram for CY-vhd9500u
I can only help a little because i have the same problem as you.. i just know the normal wire colors for aftermarket car audio stuff. Red is acc, yellow it batt and black is ground. all the other wires, i have no clue where they go or why. I know one is for the parking brake but im not sure what wire that is but i know it has one because it has to by law.
Aug 09, 2010 | Panasonic CY-VHD9500U Car DVD Player
Panasonic dvd home theatre SA HT690
contact panasonic customer service and tell them the model# of the sub , just tell them you need a replacement , they will ship it out to you at a reasonable charge and sometimes they,ll send them out for free if the unit was just purchased because you can tell them it was,nt with the unit and that always seems to work for , Hope i was able to help and if you think i was helpful please leave a nice rating Thank you sincerely glenn mayer
Mar 04, 2009 | Panasonic sa-ht930 Home Theater Audio...
Output Power of a Technics SA-DV250 sound system.
100 watts per channel both channels driven into 6ohm. You can download the owners manual at http://www2.panasonic.com/consumer-electronics/support/ (Technics and Panasonic are both made by the same company) Then enter your model #. the specs are on page 23 of the manual.
Feb 25, 2009 | Technics SC-DV290 System
Speaker wiring diagram
Jan 28, 2008 | Audio Players & Recorders
Play button of my Panasonic CY-VHD9500U Car DVD doesn't work
i just wondering can you play your movie through your car speaker b/c i had install with this professional store and they said it can't play through the car they don't have that feather. soo please reply to myeye06@yahoo.com to let me know thankz
Nov 26, 2007 | Panasonic CY-VHD9500U Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
