Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Broken bulb/liquid crystals in sharp aquos tv
Was accidently hit with inflatable beachball and now all we have is rainbow lines that runvertically and black and white lines that run horizontally
  • Anonymous Jul 11, 2008
    I have the same problem, the tv is still under warranty, I have told by Sahrps service provider it is not covered.
  • bc3tech Aug 21, 2008
    I didn't hit mine w/ ANYTHING and it has been working fine since purchase in Dec '06. Turned it on this morning and bam - about 1cm wide verticle bars in R G B all the way across the TV. I played w/ switching inputs (with NO inputs turned on) to no avail. Finally I hit the TV's "menu" button and BAM, all back to normal...
    I am wondering if I should be calling best buy to collect on my service plan - advice?
  • Sharp Master
  • 1,689 Answers
The screen is damaged. This is the large LCD screen itself. You can bring the set to the factory service rep for an estimate. You will most likely find that the cost of servicing the set will probably exceed the cost of buying a new set.
Jerry G.
Posted on Jul 03, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
What's the difference between an LCD tv and an LED tv
LCD stands for liquid crystal display. A led tv uses pixel sized leds to make the picture.
Feb 08, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Colored lines in picture. It looks broken from inside television The tv was dropped on corner of tv stand by husband Can this be repaired? It's a Sharp LC - 20SH6U 20" Liquid Crystal Television
Yes it can be repair if this is under warranty then u can give a replacement for this and if thics not under warranty then u have to go to nearest TV repairing center .
Sep 02, 2011 | Sharp AQUOS LC-20SH6U 20" EDTV-Ready LCD...
Hit sharp lcd hdtv tv with a water bottle. now there is a mark on the inside and a rainbow of colors 5 " wide from the top to the bottom of tv. its not a aquos. its a lc52sb57u
WIthout actually seeing the mark, it sounds like you may have crasked the panel. If that is the case, the only remedy is to replace the panel. I don't have listing for the panel itself. You need to contact Sharp directly to get a part number and cost.
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
A ball hit my liquid plasma sharp tv
The cost of purchasing a replacement screen will exceed the value of your television.
Aug 31, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Wii Controller into TV - - Very Bad
An LCD TV, from front to back, consists of these layers:
protective film - <1mm thick
liquid crystal cells - <1mm thick
charge screen - <1mm thick
backlight panel - 5-10mm thick
metal heat spreader - 2-5cm thick
controller board - 1mm thick
Your son most likely damaged the liquid crystal cells...
Unfortunately unlike normal TVs these are precision assembled, and there isn't much you can do to fix it.
It is possible to replace the screen, but it involves replacing the entire unit, from protective screen right to controller board. In other words, almost everything except the plastic case.
Unfortunately I think the tv is busted permanently, and it will cost more to repair than to replace.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Liquid Crystal TV, LC-15AV4U
you would need to find a servicer to do so, but it will cost you at least 80% of the original cost to get it repaired
Dec 12, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
352 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
