Question about LG WM2688H Front Load Washer
Can you add clothes to washer after cycle starts?
On LG WM2688H Front Load Washer, I use Sanitary cycle a lot. Can you override the door lock to add clothes at any point? How?
  • 3 Answers
Although this isn't a great solution, it is the the best I've found to add a couple of clothes to a Sanitary wash:
  1. Hit the power button twice to stop the wash, turn it off and turn it back on.
  2. Select "Normal", cold/cold temperature, and start the new wash program.
  3. After filling with cold water for a couple of seconds, press pause, open the door and add your clothes. Note it will be very hot inside (don't get a burn). If the door won't open, let it fill a little longer and then try pause it again.
  4. Once the clothes are loaded, press power twice, select the Sanitary program you want and start the wash again. The washing machine is smart enough to know it is already full of water and clothes and it skips the weight calculation (the "time estimate" by spinning the load to figure out the weight).
Note this doesn't drain much of the water so it is a lot better than using the drain cycle, waiting for it to cool a little, adding the missing clothes, and starting a new Sanitary wash, complete with new detergent.
It does add a little cold water so the first part of the Sanitary program will be a little cooler than it would normally be, but not by much.
Posted on Mar 01, 2009
  • 106 Answers
If you try this you are asking for trouble.............
Posted on Feb 25, 2009
  • 161 Answers
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Posted on Jul 03, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
I overstuffed my GE front load washer and now the door won't unlock. How do I manually override the door lock feature? Thanks!!
Let it run through its cycle. At the end take 1/4 of the clothing out put it aside in a hamper. re run load with some of the clothes taken out. Then washer the other clothes afterwards.
Mar 05, 2010 | GE WSXH208A Front Load Washer
Clothes stink!
Odor from your washing machine is being transferred to your clothes.
The washer must be cleaned first or it will "reinfect" your clothing upon washing. The secret is to clean the "splash area" just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area add a washer cleaner to a full load of laundry and wash in a hot setting. The added bulk of the laundry will raise the water level to include the splash area. During this cleaning intermittent pausing to soak will give the cleaner time to dissolve the moldy mess.
Also, leaving the door open makes the problem worse because it dries out the residue which makes it harder to remove.
Jul 18, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fungus build in the washer
Clean the strainer, located between the drum and the pump, and run an empty load with bleach on the sanitary cycle. Usually, to access the strainer, the kick panel has to be removed.
Regards, --W/D--
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Adding clothes after wash started
It is best to finalise what clothes you want to wash, regarding front loaders. Or if you stop the machine, you have to wait for a couple of minutes for the door mechanism to release the lock, before u try the door. At times the door won't open for there is water in there; & if you force the door you'll damage the door assembly. So a lot of caution here!
May 09, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Stinky Washer
We had the same problem with our front loader. (after only a year) We ran a load on "sanitary" setting with bleach. After that we leave the door open after EVERY load. That has fixed our problem
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Build up of black "gook"
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Aug 20, 2007 | LG WM-2277HW Front Load Washer
LG WM2688H Front Load Washer Logo
424 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
