Question about GE Heating & Cooling
I PURCHASED AN A/C MODEL #ASH12ALS1 AT SAMS. BUT I CANNOT GET IT TO TILT DOWN ENOUGH FOR IT TO DRAIN. WHAT DID I DO WRONG IN THE INSTALLATION? DO YOU HAVE OTHER PICTURES THAT SHOW A MORE DETAILED WAY OF INSALLING IT? THANK YOU TONY.
    Novelist:
  • 161 Answers
As long as the water is not coming inside you don't have a problem. Some air conditioners don't drip.They have a slinger ring on the outside fan. This picks up the water and throws it through the condensor helping to cool it and evaporate it. If you have water inside prop up the inside part with a book or something It has to tilt slightly towards the back. The other problem is it could have a blocked internal drain. Take off the outside cabinet and look. There is usually some kink of chanel for the water to get from front to back.
Posted on Jul 03, 2008
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
Aug 19, 2017 | Frigidaire Heating & Cooling
Our window air unit is leaking into the house. It was purchased it earlier this summer and has worked fine until now. We don't see a drainage hole on the outside and the manual said nothing about a...
Two things can cause the problem you're having. Either separately or collectively.
1. The drain hole in the drip pan near the rear of the unit is clogged.
Sometimes finding the drain hole can be a challenge. As the clog will blend in with the hole. Patience & persistence is what is needed in locating it. A pipe cleaner works well to clear the clog.
2. The rear of the unit does not have enough downward tilt.
The general rule of thumb for rear downward tilt is 1/4' to 1/2". This allows the water to flow to the rear of the drain pan and thru the drain hole. Rather than into the house.
Hope this helps you & thanks for choosing FixYa..
Aug 19, 2011 | Heating & Cooling
Why is there no drain hole for condesation to drip out?
Some of the Friedrich units will drip out in the back of the unit. There may be just a small bend in the base of the unit allowing a certain amount of draining just behind the rear coil. Most units require some water to remain in the back of the unit to help cool the unit off. This is why tilting in the window is important. Be sure not to tilt it too much or too much water will drain, causing the unit to overheat. Be sure to tilt it enough to where the water can drain properly or the water may drain in the house, down the wall.
Jun 20, 2011 | Friedrich CP18F30 18000 BTU ThruWallWindow...
My victoria and albert bath does not connect at the drain. the shoe tube plus the o ring and the foam washer does not make contact with the tub and strainer sufficiently enough to prevent the vicoria...
Hi Jennileefish,
It's possible that you may have purchased the wrong drain. A clawfoot or pedestal tub requires a different type drain that is curved to fit the slant of the tub.
There are many companies out there that sell these. I would contact the company where you purchased the tub and describe the problem. Having worked with this type tub I know there are specific drains required in many cases.
It's always possible that even if you purchased the tub and the drain at the same time from the same company there could have been a mix up in shipping or even a malformed part.
Most companies have a help line or live chat and will be happy to help you find out if the problem is a bad part or simply the wrong drain set up. I hope this helps you diagnose the problem.
Feb 13, 2011 | Victoria & Albert Asia Bathtub by Victoria...
I purchased a Garmin at Sams Club. Around $200.
Go into the tools section of the unit. There is a way to set the volume level there.
Nov 06, 2009 | Garmin Nuvi 350 Car GPS Receiver
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Schematic for Zenith SF 120 console/Chassis 3B31 and 9B22
This model is old enough to not be available electronically. Your best bet is to locate a Sams Photofact copy of the manual. Check your local library as many carried these. Otherwise, check the web for Sams. These are usually available for purchase for less than $15.
Dan
May 05, 2009 | Audio Players & Recorders
How do I hook up washer drain pipe?
You'll need to seek the advice of a home repair or appliance repair - as your description of your connectors is vague.
They likely have the appropriate adapters.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 31, 2009 | Washing Machines
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
Heating & Cooling Logo
82 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
