SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
SOURCE: I have a hoover frost free a class fridge freezer
sounds like a bad thermo stat it is not maintaing the proper temps in fridg area....
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
