Question about Linksys WRT54GL Wireless-G 54Mbps Broadband Router w/Linux all-in-one Internet-sharing Router With 4... (WRT54GV4)
Help me!!!!!!!!!!!!! i plug my cord right in to the modem no router. how can i get my live conshin to be open
    Problem Solver:
  • 18 Answers
Do you have the software C-D for your router? If not go to Linksys.com and chose your model and d/l right from the website. There you can get the latest firmware. Then follow the instructions (it should have pictures to go with) then you should be up and running within about 25 minutes.
Posted on Sep 16, 2008
Cant connect to live
To connect to Xbox Live, you will need a wired Ethernet cord plugged into the back of your Xbox console. If you are using a Xbox 360 Wireless Adapter, you have to plug it in into the back of your Xbox located to the bottom left from flat on the ground. Also make sure you have a strong enough connection on your internet, and router/modem. Make sure your Xbox console is close enough to your router or modem as well. Also attempt to reset your connection and modem/router and see if this works. 1 or 2 bars are to low for Xbox Live gameplay. 3 or 4 bars are just quite enough. I hope this helped, just contact me if you have further questions or problems!
Jun 27, 2011 | Microsoft Xbox 360 Console
Xbox live Internet issues
If you have a wireless router and modem unplug both of them leave unplugged for about 5 minutes plug in modem first after its all the way booted up plug in the router that should work and also make sure all cords to modem and router are plugged in good.If you don't have a router just unplug the modem for 5 minutes and plug it back in and let it boot all the way up then see if you can get on.
Mar 30, 2010 | Microsoft Xbox 360 Console
Internet problems
try resetting your modem, not the router. Unplug it, wait a bit and plug it back in. the modem needs to see the routers ip address so it allows connectivity. Right now the modem has your computers ip address and doesn't see the router, until you reset it. try it, it should work.
Dec 30, 2009 | Linksys Wireless-G Broadband Router
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Jan 04, 2009 | Arris SURFboard SB5120 Modem
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
