Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Xbox360 network adapter
Hi my network adapter blinks red quickly and then turns off when i plug it in to the usb ports on my xbox360 any help will be much appreciated
    Problem Solver:
  • 9 Answers
Make sure all your cords are tightly plugged into the XBox and that you are using the slots to clip it on. If all else fails return and get a new one.
Posted on Jul 09, 2008
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Dell inspiron 1525. problem with comstudio virtual adapter... network device im sure base system device. and also usb root hubs all not working missing driver . except one of the usb root hubs are...
Check for spyware. They can stop some USB ports from working. Also. Under system properties and device manager. Scroll down to USB devices. Right click on them and there is an option for. Turning off the power save option.
May 16, 2011 | Computers & Internet
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
How to setup xbox live
To set up the connection via a router unplug the router and the modem and turn off the 360. Connect an Ethernet cable to one of the out ports of the preexisting router then connect the cord to the back of your 360. Plug everything back in and turn and give the modem and router about 3 minutes to reboot.
Once you have given everything a few minutes to reboot you can turn the 360 back on. If you have already set up a gamer profile you will see the Xbox Live screen. If you have not set up an account you will be prompted to do so. All you need to do is follow the on screen instructions. It is a pretty cut and dry process and should not take more than 10 minutes of your time.
If you want to go wireless or you must go wireless you will need to get the Xbox360 wireless network adapter. The adapters are available at most stores that sell 360 games or you can order it online. Once you have the adapter unplug any Ethernet cable you might have plugged into the 360 then clip the Network adapter to the back of the 360. It is really easy to see where it belongs, but just in case, the adapter will sit right alongside the USB port which is right above the Ethernet port. Once you have clipped it in plug the USB cable that is attached to the adapter into the port on the Xbox 360. Flip up the antenna that is laying flat against the adapter and you are set, well almost set.
Turn on the 360 and head into the System tray. You will see Network options, go ahead into that screen and follow it through to the "Edit Settings" subcategory. The Network name should appear on a list of available networks. Select your network and enter the password, if there is a password. Exit out and you should be ready to play.
Nov 27, 2010 | Microsoft Xbox 360 Elite Console
The adapter doesnt blink, and wireless adapter is not found.
If it doesn't blink:
- try to uninstall it completely
- remove the adapter from the USB port
- install the software again
- leave the WUA-2340 out of the computer's USB port until you have installed the software
- when the installation routine tells you then insert the adapter into the USB port
- you follow the instructions from there.
It should work if you do it that way.
Jun 20, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
Xbox 360 adapter
Just taking a wild guess here, but;
1. is the wireless adapter plugged into the usb port, not the ethernet port.
2. Is there the possibility that the adapter is broken?
Mar 28, 2008 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter
What exactly are you refering to Here ( adapter ) The Power Brick, A wireless or wired Controller ?
There are 2 USB Ports on an XBOX 360 same place Front R/H/S Slot Side By Side.
Mike @ Compurepair.
If it,s Orange ( whatever it is youre refering To ) then it,s in standby Mode. Red ( error/Fault ) Green working OK.
Hope this helps.
Feb 24, 2008 | Microsoft Xbox 360 Console
Xbox360
Are all four quadrants blinking red around the power button? This indicates that your Audio/Video cable is not plugged into the 360. Unplug it and plug it back in, or make sure it is securely plugged in.
Any other problems, contact Microsoft and 1-800-4-MY-XBOX and they will promptly fix it if it is still under warranty.
Jan 28, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
