Question about Kitchen Ranges
Maytage PER5710BAQ locked!
My 13 year old was baking muffins and pushed the lock side on our stove. The oven is off and it is still locked.
We were not cleaning the oven. The oven locked light is off and it still will not open.
    Novelist:
  • 161 Answers
Put it into the clean cycle. and let it clean. Then see if it will release after it completely cools If the pan of muffins or anything else is still inside don't let it clean more than 10 min. as it will catch fire. Just let it start cleaning and shut it off yourself. If you can program the clean time for less than 1/2 hour try to let it shut off itself. If there is nothing inside let it go the full amount or at least 2 hours.
Posted on Jul 03, 2008
When I was using the stove...the door locked and F-3 showed up what happened
it sounds to me like you have a self cleaning oven and may have somehow gone into the cleaning cycle
Oct 07, 2012 | Whirlpool Accubake RF362LXTT Electric...
Our Kenmore oven door also remained locked after I manually switched the cleansing level just over the oven door to the right side in hoping of locking the oven door to prevent my 19M daughter from opening...
You are correct. The locking mechanism has a heat sensor which will not allow you to open it while its hot. You should only use the lever while in self-clean mode. It will not let you open it because it heats to about 900 degrees during self-clean and could cause serious harm if anyone opened it while it was that hot.
May 21, 2010 | Kitchen Ranges
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Oven door
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Apr 04, 2008 | Kitchen Ranges
Maytag Range
F1 on Maytag = Bad touchpad or Clock.
Mar 20, 2008 | Kitchen Ranges
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
162 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
