Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000 gtl
I just received a Cobra 2000 GTL from Ebay. When the radio is on there is a steady tone, similar to the sound of morse code is the speaker. The volume control has no effect on the tone. You can still hear other stations through the speaker, but the tone overwhelms it. I bought this radio used. It looks like someone tried to jump the PLL with the speaker switch, but they didn't change the PLL, it still has the MB8734. I removed the jumpers to the PLL.I plugged the speaker into all outlets, SP1, SP2, AUX, and even the headphone jack. Any help is appreciated. Thanks
  • mr_mudduck Jul 05, 2008
    I have the same problem with my Cobra 148 GTL, When the radio is on there is a steady tone, similar to the sound of morse code is the speaker. The volume control has no effect on the tone. You can still hear other stations through the speaker, but the tone overwhelms it. It will also transmit this tone mixed with your own audio. I don't know if this is related but if I adjust the mic gain control the tone will change pitch. Have tried different working mic and your trick with the earth wire to the RX/TX mic pins and the tone is still there. Can you help?
    Problem Solver:
  • 6 Answers
Cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Posted on Feb 05, 2010
Very low tx
Posted on Oct 31, 2008
    Brigadier General:
  • 6,966 Answers
It is a fairly common practice to make use of the CB/PA and/or speaker switch to modify this radio to add a few more channels (hot wiring the PLL pins). Perhaps your best option would be to rewire the unit back to factory specs. A schematic diagram would help you get them properly connected. This page is dedicated to Cobra 2000 GTL and have links to the schematics and other documents. This is of course assuming that you have a more than just familiarity with electronic components and circuitry, use of a DVM and a soldering iron (knowing the MB8734 is PLL) .
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 03, 2008
I
i have yhe same problem
i have clear the contacts on ptt switch and the all contacts in the volume potentiometer
Posted on Aug 01, 2008
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Reset on the back of cobra gtl 2000 cb radio
the reset button is used to reset the cpu when doing mods.try replacing with momentary press switch.
good luck
ken
Apr 04, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Replacement meter swr/rf meter for 25,29 gtl cost
There are a lot of meters on ebay. That's where I get mine.Usually around $5.
As for the other parts, only thing I can recommend is a google search.
Mar 18, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
148 GTL PROBLEM
sounds to me like the final driver is blown, try replaceing it with a new one.
Apr 24, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
1,892 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
