Question about Sony PlayStation 2 (PS2) Console
Jammed PS2 DISC TRAY
I was going to play a game on my ps2 but the disc tray was jammed so i had to pull it open but it would not go back in i am realy worried so please send me a reply ASAP PLEASE IM BEGGING YOU!!!!!!!!!
    Problem Solver:
  • 16 Answers
If your ps2 is in the upright position this could be the problem as the disc will not sit propeely and rattle around and cause scratches, the best way to have it is in the downright position as the disc tray will be flat and wont slouch down, try turning it on and pressing the close switch.
Posted on Jul 05, 2008
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
How to play movie dvd in playstation 2 ?
open dvd case.
take out disc.
place disc on ps2 disc tray.
put disc tray into console.
enjoy.
Jul 08, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 fell on the floor!
Use to have this problem alot, there is a track on the under side of the tray a little plastic pin follows, it has jumped the track, do not force it closed or you could break the track, hopefully it isnt broken already. Have you ever opened a ps2 before?
Dec 12, 2008 | Sony PlayStation 2 (PS2) Console
PS2
There may be many problem that have occurred to make this happen, here is a list of the three most common:
  1. You MAY have a disc jammed into the PS2, making it impossible to open (and/or) close. This could have happened by someone accidentally putting one disc right on top of a disc that is in the PS2, and not taking the other game, movie, etc., out. How to fix? Best Buy, Circuit City. Another way this could have happened is: an earthquake, flood, SOMETHING, may have happened that made a disc fall out of the tray (while INSIDE of the PS2) and jam it up, to fix this, you have to do the same as the first option.
  2. The motor is broken, this is pretty self explanatory, the motor that makes the disc drive open and close is broken, solution? Same as before.
  3. Your PS2 has reached it's prime, and gone over the hill, sorry buddy. :(
I hope you found this helpful, sincerely- animation508 (youtube username)
Sep 23, 2008 | Sony PlayStation 2 (PS2) Console
When I go to play a game on my ps2 and put the game in the ps2 eye prevents the disk from spinning I have the newer ps2 that is slim the eye that reads the disk keeps sliding up and the disk does not get...
Does this happen to all of your Discs? If you know someone who also has a PS2, try to run your discs first on that PS2...If they worked, then probably either the lens of your PS2 needs to be replaced, or it only needs cleaning. Or it is also possible that your disc isn't inserted on the disc tray properly...and by "inserted properly " on the tray I mean is to make sure that the 3 pins on the spinner of your PS2 are sticking out of the hole on the DVD and thus gripping the disc...
Aug 01, 2008 | Video Game Consoles & Games
Disc Tray
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
PS2 auto shut down when disc tray is close
big mistake. never use ps1 cables on a ps2. i made the same mistake once.
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
178 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
