Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenovo N100 does not switch to battery power
I have a LENOVO N100 laptop. The laptop is working fine with direct power. But when I am switching off direct power the laptop is switching off. Battery charge is showing 60%. Another problem is while on direct power it is not charging the battery (I get the message "plugged in, not charging"). So, VERY SLOWLY the battery power is running out day by day. Any help will be highly appreciated.
  • Anonymous Apr 01, 2014
    my lenevo g410 works only with direct supply and in start up charging indicator shows 4 blings and it gets off please help me
    Sergeant:
  • 313 Answers
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Posted on Jul 03, 2008
  • John Dyck
    John Dyck Dec 19, 2014
    I had a similar problem which I fixed by charging the battery with an external power supply set to current limit at 1amp and 12.6volts. After several hours the current dropped to near zero and the battery now works fine in my laptop.
How do i enable my wireless connection on my lenovo 3000 N100
The wireless switch is at the front side of your Lenovo 3000 N100. (see pic.1). Press Fn+F5 to confirm if your wireless switch is on. If required, switch on the physical switch for your wireless connection.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 29, 2011 | Lenovo 3000 N100 Notebook PC
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Lenovo 3000 Notebooks : N100 Power Failure!
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Jan 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
No battery charging
you need to replace the battery.
Nov 12, 2008 | Lenovo 3000 N100 0689 Notebook
Battery problem
hi monikag i don't know how old your computer is but it seems like the battery has failed and you will need to get another battery.
I had the same problem on HP laptop one week after the waranty run out, so i hope you have better luck.
hope this helped.
Nov 05, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenovo N100 dual centrino
visit lenovo.com u can get certain things to make your laptop faster.......
Aug 18, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Radalin -
I've done a lot of laptop repair, and have run into similar issues with various laptops. What you've described sounds to me like a problem in the power circuit on the motherboard. There are a number of things that can cause this, and, generally, none of them are an easy fix - blown capacitor, bad power IC, bridged leads on a relay. If you have any experience working with integrated circuits, you can always test the power loop on the laptop with a multimeter. However, you may want to look into obtaining a warranty repair, or purchasing an extended warranty so that you can get a warranty repair; if there has been no user error(i.e. fluids spilled on the computer, dropped computer, left in excessive heat or humidity), then its a factory defect on the motherboard.
Hope this helps!
-thinstatic
Jun 11, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
276 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
