Ihave amaxtor diamondmax plus 9 120gb sata/150 hdd iam not shure of the sata cable plasements from hdd to comp.
    Problem Solver:
  • 17 Answers
Any of the Sata ports on the mainboard is sufficient but go for "0" or "1" because they may already be enabled. Couple things though... 1.) go into set-up and make sure the port is enabled 2.) make sure you are using the correct data cable for your Hard drive. (trust me on this one, I learned the hard way!)
Posted on Jul 03, 2008
My Maxtor DiamondMax Plus 9 80GB ATA/133 HDD with a X-Media USB2.0 TO IDE & SATA cable adapter
Check (under high light) flat IDE cable pins on the mini-board. Many pins, and many chance to loose contact.
Feb 10, 2014 | Computers & Internet
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
My hdd is not working. which hdd model can i buy instead of mhv2080at?
Bro i recommend Maxtor DiamondMax Plus 9 80 GB (6Y080M0)
Hard Disk specifications:
1.0. SATA cable hard disk.
1.1. include 80 GB model for test series.
2. includes 8MB of cache.
3. with fluid dynamic bearings it mean that it will runs nice and quiet and can do fast transfer of informations.
May 28, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Change a hard drive
As a general rule, SATA drive like the DiamondMax Plus 9 160 GB Hard Drive can be made either master or slave by just plugging the drive cable to the appropriate alternative SATA port on the motherboard without changing anything on the drive. MAKE SURE YOU UNPLUG THE PC FROM THE MAIN POWER FIRST! Most motherboard will have two such ports on the motherboard in close proximity to each other (just follow the 'flat' usually red or yellow cable from the SATA drive towards the motherboard to locate the ports). Hope it helps.
Dec 21, 2009 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
My hard drive is going bad. So says my HP Compaq dc7100 SFF
Instead of posting here, why don't you look for a dealer.
You can buy hard drives just about anywhere now - and it doesn't have to be Maxtor.
Oct 18, 2009 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
