Question about Maytag MDG9206 Dryer
Noise in dryer
My dryer sounds like an MRI machine with LOUD banging every time I use it. It is a Whirlpool front load gas dryer. Can I fix it myself?
  • Anonymous Nov 14, 2008
    it doesn't bounce around, it just makes a horrible banging sound. It still works, it's just the noise.
    Scholar:
  • 170 Answers
Does the drum turn smoothly, or does it bounce around? If it bounces, it could be the bearings in the drum wheels going out. The wheels would need to be replaced ($20 on up).
Posted on Jul 05, 2008
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
My washer is not quite 3 years old and has started a loud banging sound especially when it spins, it sounds like an MRI machine
One of the dampers has gone so the drum is allowed to move too far from its centre when it is spinning and is hitting the outer shell
Once it gets out of whack the machine will dance across the floor if it is allowed to.
You need a man that can
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
Apr 11, 2009 | Whirlpool Dryers
Noise from washing machine
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fddfs
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
