Question about Jenn-Air PRG3601P Gas Kitchen Range
Prg3601p oven Hi my jenn air prg3601p oven is weither slow to turn on or doesnt turn on at all but the broiler does turn on - please advise thanks
I also have this problem Ihave replaced the igniter twice this helps some for a while  I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
Posted on Sep 14, 2008
Oven not working
http://www.geappliances.com/search/fast/infobase/10002629.htm Follow the driections here to see if they work I had the same problem and this fixed mine.
Jul 30, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
Broiler does not light....Put in new ignitor; still not working. Checked orfice to make sure its LP and not Natural gas. Its number is #56...Is this correct for LP?
The Jenn-Air Broiler LP broiler orifice is part number: AP4091112. A picture of the part is here: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-orifice--broiler--lp--item-number-ap4091112.aspx . (To me the number looks like 65 to me. The natural gas version is number 47.)
Check the current draw at the igniter. (The meter must be in series with the igniter. I know the bake igniter needs to be above 3.2A.) Other possible causes of the problem are a selector switch problem or the glow bar. (These are things to check if the oven works.)
I hope this helps.
Jul 30, 2011 | Jenn-Air PRG3601P Gas Kitchen Range
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn Air oven keeps beeping F2 and the upper oven broiler won't shut off. We do not have a manual. Please help!!! Briezee85@netscape.net (925) 672-1279
Sounds like a welded relay on the control board. You can replace the board or have the board repaired for much less expense.
Feb 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
OVEN WILL NOT CLEAN JENN-AIR SVE47100B
It was recommended to me by your service that I call a service person. I did that. thanks.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn Air Oven Repair
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
Oct 08, 2008 | Jenn-Air Ovens
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jenn-Air PRG3601P Gas Kitchen Range Logo
241 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
