Question about Freezers
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
  • 72 Answers
SOURCE: 50-plus-year old Kelvinator chest 14 ft3 freezer.
Use a temp controll from another freezer, it is just a temp switch.
DIY repear and diagnosic help:
Posted on Nov 12, 2007
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
  • 20 Answers
SOURCE: Kelvinator chest freezer not freezing
SUM HUSBAND. call the handyman N-E-WAY
Posted on Jun 09, 2009
  • 36 Answers
SOURCE: my chest freezer has stopped working . kelvinator
If the light isn't even coming on, check for voltage at the outlet. If that is good, check the bulb in a lamp or drop light. If both those check out, then the fun starts.
Could be that the thermostat is stuck (rusted) in the open or off position.
Posted on Mar 03, 2010
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
Power off for electrical repair. Plugged floor freezer back in and a loud buzzing noise is ongoing. Not sure if this is a temperature alert or if there is another problem. Thanks for your help.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
May 04, 2011 | GE Freezer  14.8 Cu. Ft. Manual...
How do i defrost chest freezer
unplug unit and open door, it should have a spout at bottom to connect drain hose
Aug 22, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Need defrost element for 1996 Kelvinator Freezer
Fixya is unable to suggest sources for a Kelvinator defrost element.
Mar 04, 2018 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator novelties chest freezer
check the defrost timer, defrost limit, and defrost heater.
Apr 21, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
81 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
