Question about Magic Chef Microwave Ovens
We need to know how to replace a magic chef microwave light bulb, please!
  • Magic Chef Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
Replace light bulb.
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How do i change ligh bulb magic chef mcd11e3b
Unfortunately I do not believe that the light bulb is able to be replaced. I would go here and send them a question regarding it.
Mar 05, 2010 | Magic Chef MCD1110ST Microwave Oven
1992 magic chef (panasonic) microwave. Model M15E-5B. In a RV with very little use. Ran empty. 5 seconds blue flash at top of oven. Panel lights but only time pads work. Seconds, minutes, ect. Fix with new...
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
Mar 31, 2009 | Magic Chef CMV1000B Microwave Oven
Replace light bulb in Magic Chef MCD1611
Remove cover and look for light. Special torx is required to loosen screws.
Feb 19, 2009 | Magic Chef MCD1611 Microwave Oven
Microwave would not turn on
Sounds like the control board is bad.
Sep 24, 2007 | Magic Chef MCD1311ST Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
