Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
Replacement shelf when we brought this fridge there was no shelf for the freezer. where can we get one??
  • Anonymous Mar 12, 2014
    Take out broken freezer shelf clips and replace them with new ones
  • 61 Answers
Search Google is probably best bet
Posted on Jul 03, 2008
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge Side Not cold enough
open the freezer and check if you can hear the freezer fan running if not replace freezer fan. also you could have a defrost problem.
Apr 07, 2007 | Frigidaire PLHS39EES Stainless Steel Side...
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
57 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
