Question about Stainless Cruise 49 Marine Refridgerator - Measures 20 " H x 15 " W x 18 " D. - Steel model - CR0...
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the fan and it hasn's started since. Been an hour. The compressor seems really hot.
    Novelist:
  • 161 Answers
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Posted on Jul 03, 2008
I have a three year old Amana bottom freezer double doors 25 cu ft. The freezer is working fine but the fridge is not cooling at all. I tried defrosting had it unplugged for two days. Tried cleaning the...
There is an evaporator fan locateed inside top of the freezer compartment. It is normally hidden behind a plastic cover. It should be running whenever the Fridge is calling for cooling. Check to see if this fan is running. My suspicion is that it is not running. Replace this and you should be back in business.
You will see the fan assembly at the bottom right corner of the picture.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174550&diagram_id=28601573#d28601573
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
You say clean outside coils and fan motor coils. Where are they?
The "outside" coils that you are looking for on a refrigerator will be found either on the back, or in the case of your Amana, on the bottom - behind the toe space bezel. There are no coils on the back of the fridge.
The coils are usually thin, black grates that contain the refrigerant. Be careful not to damage them when cleaning. Open the freezer door (yours is a bottom freezer type) and simply grasp at the top of the bezel an gently pull away from the frame.
Use a narrow crevice vacuum tool attachment to pull the dust and debris from the coils. Use a flashlight to see beyond the very front. You may also wish to unplug the fridge so that you do not damage the fan if it is struck by the tool while running. You should vac the coils annually or more frequently if the fridge is in a dusty area - or there is a lot of pet hair collecting on the coils. Some fridges also have the fan hidden behind a removable panel on the at the bottom of the back side of the fridge. If cleaning fan blades - you must unplug the fridge before attempting. Vacuum any dirt and dust on visible coils seen near the fan.
Mar 29, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
The bottom freezer on my Maytag BR22 is not
Look at the inside back wall of the freezer, If you see that it is built up with frost. You have a defrost problem. If not, check the coils under the bottom, make sure they are clean and not covered with dust. If so clean with vacuum and long brush. If they are clean, check the fan that blows on the compressor. Make sure it's running. If not you have a bad fan. Last be sure the fan inside the fridge is running.
Please rate solution
Sep 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
My amana scd23vbw
first do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Sep 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Stainless Cruise 49 Marine Refridgerator - Measures 20 " H x 15 " W x 18 " D. - Steel model - CR0... Logo
304 people viewed this question
Top Stainless Refrigerators Experts
Dan Webster
Dan Webster
billconfused
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
