Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
OVERHEATING COMPRESSOR My Kenmore side by side compressor keeps overheating. When I unplug the unit for a few days it will work again, but then overheats and stops cooling. The middle seperator between the freezer and the fridge is hot to the touch. (very hot). The fan underneath never shuts off. I am not sure why it is over heating.
  • 958 Answers
You can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Posted on Jul 05, 2008
Subzero fridge door left open. Has a new compressor just recently. Is there a reset button on the compressor to get it going again
The compressor has probably overheated. Leave the fridge unplugged for a few hours until it cools down. If you keep trying to use it, the compressor will fail again. They have a self resetting thermal cutout but these will fail if the compressor keeps overheating.
Sep 17, 2017 | Refrigerators
Kenmore refrigerator stopped cooling 6 days ago and started working again 2 days later but not very cold.Stopped cooling again 2 days ago.Now it is frosted up in the back of the freezer,What could cause...
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Sep 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Trio not cooling
sounds to me as if the compressor is overheating and shutting itself down (the buzzing noise) Once a compressor overheats it throws itself into what is called thermal overload. There are several reasons that a compressor will do this. But you said you turned it off and back on and it worked for a while. If this is so then it is possible that your unit could be low on freon or the coils under the base of the fridge has a lot of debris on them. To clean the coils just purchase a coil brush from your local hardware store and using a flashlight to see, brush all of the debris off the coils. make sure to unplug the unit before doing this. If the coils are clean then you need to have the pressures check on your compressor to see if the proper level of freon is there. An appliance tech should be able to check this for you for a minimal cost. Good Luck
Dave
Jul 17, 2009 | Maytag MSD2656G Side by Side Refrigerator
Kenmore refigerator keepsgoing into defrost mode
Hi, If you changed relay, overload, & capacitor on the compressor and it still clicks on and off, the compressor has gone bad and will need replaced. Is this unit under five years old?
Vic
May 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Keeps clicking on and off
Hello.
It sounds like your condenser fan might not be working, and causing your compressor to over heat. When you turn it down, the thermostat isn't demanding as much run time so the compressor isn't on as much, thus not overheating. Take off the back panel near the floor and see if it is turning or not. Also make sure the condenser coils underneath the frig are clean. If not them vacuum them out.
When it comes to the ice issue, you will need to be more specific. Where is the ice forming? And is it ice or frost?
Dec 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator and freezer not cooling properly
you have a deffective compressor the humming that your hearing or the clicking is the relay on the compressor trying to start the unit, the compressor is stuck and cannot start, leaving it unplugged lets the compressor cool down, but as it tries to recool the unit it gets orerheaated again, thus the bad compressor
Apr 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Dec 26, 2007 | Refrigerators
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Quick Fix?
The compressor is locking up when it gets hot. We have seen alot of this on the units with Tecumseh compressors. If it is less than 5 yrs old it should still be covered by the sealed system warranty and repaired free of charge.
If it is out of any warranty, there are "fit-all" compressor starters with start capacitors built in them that give it a little extra boost on start-up. They are called 3-in-1 or kickstart starters. This will usually buy you a few months until you can replace fridge.
If it is covered by warranty but will take a few days to get repaired, you can get by ok by unplugging fridge at night and plugging back in in the morning. This is what I tell my customers when I have to order a compressor and so far they have been able to keep from losing food.
Nov 05, 2007 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
797 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
