Question about Garmin nuvi 350 GPS Receiver
BELT WON'T TURN
WHEN I TURN ON THE PTO SWITCH, THE BELT DOES NOT TURN. THEBELT SEEMS TO BE TIGHT, BUT WHEN YOU PUT THE DECK BACK UNDER THE LAWNMOVER ANDCONNECT THE PTO BELT IT DOES NOTHING. THERE SEEMSTO HAVE SLACK IN THE BELT. I CANNOT FIGURE OUT WHAT IS CAUSING THIS. THE PTOAND CLUTCH IS WORKING FINE, JUST PROBLEMS WITH THE BELT AND IT NOT TURNING. CANYOU PLEASE HELP ME? I HAD TO PUT THIS IN THE PRODUCT LIST BECAUSE THEY HAVE NOTHING ON WHAT I NEEDED.
  • PAMELA DARBONNE Jul 03, 2008
    BECAUSE WHEN I TRIED TO ASK FOR HELP, IT INSISTED I PUT DOWN A PRODUCT, NO PRODUCT WAS LISTED FOR LAWNMOWERS. I TRIED EVERYTHING, IT WOULD NOT GO THROUGH, SO I PICKED ANYTHING TO SEND IT. MY PROBLEM AS I SAID BEFORE, WHEN YOU ENGAGE THE PTO SWITCH TO MAKE THE BLADES START AND THE BELT TO TURN, THE BELT DOES NOTHING,THEREFORE IT WON'T CUT THE GRASS. AS I STATED ABOVE, THERE SEEMS TO BE SLACK IN THE BELT.
    I HOPE THIS HELPS.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Why is this posted under Garmin GPS?
    Scholar:
  • 174 Answers
Well, if he can't get his mower to work, how the hell should he know what a gps is for...
Posted on Jul 23, 2008
How do I get tension on the belt that drives the deck. The belt goes from the PTO to the deck but is not tight. When you engage the PTO there is not enough tension to drive the deck.
You either have too long a belt or it is routed incorrectly. Do a Google search for you make and model deck belt routing or look up on jackssmallengine.com
Sep 10, 2016 | Garden
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
I replaced the deck belt. now the engine will not turn over.
Before you try to start it up, Make sure Your PTO and Deck levers are in neutral.
Aug 28, 2014 | Garden
Belt replace instructions husquarna riding lawnmover.
If it's for the deck there's a rod on the deck you pull out to release the tension. If your drive belt you have to take the deck off.
Aug 26, 2014 | Husqvarna Garden
Why does my Craftsman Garden Tractor # 917276022 that runs but when I engage the pto it dies immediately?
well usually when this happens it;s a safety switch that's defective or misadjusted but your sure these are good Id try dropping the mower deck and try enguaging pto if it still runs you got a deck problem ,I have seen spindle bearings lock so tight that it'll stall a 46 hp tractor but that was a brush cutter deck
May 07, 2014 | Garden
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
JD STX38 mower stalls when deck is lowered
If the belt bounces then it has stretched or the belt tightener is not working. properly. Also check the shear pin in the drive pulley. If it has sheared the blades will try to turn but slip when any pressure is put on.
Jan 07, 2018 | Garden
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garmin nuvi 350 GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
