Microwave Ovens Logo
Posted on Jul 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a new GE microwave today at Walmart. We plugged it in, the lights are on. It clicks like it is trying to come on but will not start cooking.
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Jul 13, 2008
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4481327
Points
21747
Your best bet is to exchange it. They should have a 30-day exchange.
I would suspect the door or chassis is out of alignment , keeping the door latches and switches from working properly.
We're happy to help and we appreciate your thoughtful rating of our answer.
1helpful
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
My microwave power is ok, led light ok, but dosen't work what problum?
check the door switches....i had an over the oven micowave with a bad door switch....thing is the switch cost 35.99 online and i bought a counter top microwave for 39.95 at walmart
I just bought a GE 1150 watt microwave. It worked fine in the store, but when we plugged it in at home, there is no power. The outlet works because I plugged a night light in and it lit up. Could the...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
Just got today brand new at walmart wont work tried everything already disconected and all will light up but wont ever start
if its the initial start of the heating of the microwave that you are refering to then you may have a damaged keypad this couldve happened at the factory hopefully you still have the reciept and are able to take it back and exchange for a new one.
1helpful
I have a GE Microwave Model JVM 150 01 , Every thing works but there is no heat , can this be fixed if so what would be the aprox. cost . Thank You Fred My Email is [email protected]
Hello Fred. When the microwave won't heat, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
The reality of today, however, is that it rarely pays to repair a microwave oven since you can go to Walmart and get a new one with lots more bells and whistles for 50 dollars and up.
2answers
Microwave shut off
try to checked the fuse if its blown.and replace a new one,check also the power cord.
1helpful
2answers
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Light Stays ON Inside - JE2160
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
Please write back with your brand and model number if you need further help.
New microwave not starting
Chances are the oven is designed for 60HZ and your supply is 50Hz. This will cause the unit to shut down because it thinks it is not getting the proper "interrupt" signal from the power line. You can check the owner's manual (or model number tag) and the manual for the converter.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
