Question about Gigabyte GA-8I848P-G Motherboard
Does not turn on at all.
Usb socket had a brief short.
Bios scan image .....
bios c'ant trouve image harddrive ou disquette
Posted on Aug 15, 2008
I have a 1997 cavalier z24 that is having some electrical problems. The tail lights, side marker lights, and instrument cluster lights do not work. I've already replaced the fuse, but it keeps...
you have a dead short immediately after the fuse Check wiring for rub points/ pinch points. Check all bulb sockets to ensure that the power wire is not touching earth or the earth wire.
Jun 13, 2013 | Cars & Trucks
My front usb port on my pc are not working and how to fix it
If she shorted out the usb ports then you would want to replace the motherboard.
Dec 24, 2012 | Nvidia Ecs Mcp61m-m3 Geforce 6150se Socket...
Any time I plug anything into any of the usb ports on my Advent roma 4001 my laptop switches itself off. Please help!
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines.
If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets).
Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc.
If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it.
Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem.
good luck
Jan 19, 2011 | Advent Computers & Internet
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
Usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Dec 29, 2008 | Sony VAIO VGN-SZ110/B Notebook
Bamboo Fun usb device not recognized
Change the USB cable... this is the problem...
Sep 22, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
USB Device Not Recognized
Aug 28, 2008 | Crosley 0187SST Turntable
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :) sounds funny but it works :)
Dec 28, 2007 | Philips PM435S Remote Control
let me know if that helped !!!
Dec 01, 2007 | Konica Revio KD-400Z Digital Camera
Gigabyte GA-8I848P-G Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
