Question about HP Photosmart C6180 All-In-One InkJet Printer
How do i load paper
How do i load the paper for the hp photosmart c6180
  • HP Master
  • 5,568 Answers
If you no longer have the manual it can be downloaded here:
http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
Posted on Jul 03, 2008
Paper is in paper tray, however copier says "load paper in tray
The paper is not loaded correctly, push it in there all the way to the back. Also put in a reasonable amount of paper, not to little or too much. Good luck!
Aug 27, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 All-In-One and the paper is jamming ever time I try to print or receive a fax.
Check the specifications of the paper size and weight. It should be a supported paper size. Clen the rollers of the paper.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
My hp photosmart c6180 prints green photos on photo paper. it prints fine on regular paper. all my ink cartridges are hp and new. how can i fix this. i have tried several different types of photo paper as...
Check to make sure all of your contacts are clean. The part where the cartridge meets the printer. Also check to make sure you have it set in the printer properties for photo quality paper. If this still doesn't work, I would suggest trying a different brand of paper, it may be the problem with the paper manufacturer.
Oct 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 stopped loading paper
its due to the fact that paper you have loaded is being crashed inside the printer if you once again rotate the paper feeder stick and try it will work
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
