Question about Monarch 9416 (Part M09416-TT04) Printer
Nothing is printed out (paper rolls, but nothing on it!!
My 9416 does send out the paper when I print, but it has nothing (not even a single dot) on the paper.
  • 2,785 Answers
Plz try by reinstalling the drivers then check the ink status
Posted on Jul 03, 2008
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
Jul 24, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Print came only single dotted line on paper
u change the printer software, then u check.
Jun 24, 2009 | HP LaserJet 1020 Printer
Just print one and stop working monarch 9416
Isolate : disconnect from the computer, turn it off - press and hold the paper feed button while turning it on releasing only once the unit starts printing.
if it passes without error, replace the cable or try another port if it's USB.
Nov 20, 2008 | Monarch 9416 (Part M09416-TT04) Printer
Nothing printed on the paper
plz try by reinstalling the drives for the printer, check the ink status
Jul 03, 2008 | Monarch 9416 (Part M09416-TT04) Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
Feb 12, 2008 | Epson TM-U220 Matrix Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Monarch 9416 (Part M09416-TT04) Printer Logo
246 people viewed this question
Top Monarch Office Equipment & Supplies Experts
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
