Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Cant connect to computer
When i plug lambda to my usb i get no power to the lambda
  • krenc77 Sep 14, 2008
    i had to buy a new computer i could not download windowsxp service pack 2. u need 2.0 usb ports. they wanted 300$ to fix my old one. best buy had a good deal on a 4gig quad core i got a 17 incch monitor and prrinter for like 750$. i guess u need new technology like i did
I have the same exact problem. What did you do to fix it?
Posted on Sep 09, 2008
Bmw code 29a8 power management failure and l cant understand the meaning
BMW outputs codes in Hex format. The tool then reads the code and it may translate it to its own format. Some 29A.. code definitions here:
29A0 Lambda Sensor Post Cat Bank 2 Signal
29A1 Lambda Sensor Post Cat Bank 2 Signal
29A2 Lambda Sensor Pre Cat Bank 2 Signal
29A3 Lambda Sensor Pre Cat Bank 2 Signal
29A4 Lambda Sensor Heater Pre Cat Bank 1 Activation
29A5 Lambda Sensor Heater Pre Cat Bank 2 Activation
29A6 Lambda Sensor Pre Cat Bank 1 Signal
29A7 Lambda Sensor Pre Cat Bank 1 Signal
29A8 Power Management Network Failure
29A9 Power Management Battery
29AB Torque Request via CAN
29AE Tank Cap
Code 29A8 i
t's a NETWORK management fault, related with tne main computer. Will need to visit BMW dealer to delete or reset it.
I hope helps with this.
Mar 18, 2011 | 2009 BMW 5 Series
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda not detected
the usb could be the problem. when you plug it in does your comp make a noise if not it is the usb if it does than the drivers are not in sometimes its a program problem try going to start-mycomputer-(cd/dvd drive right click on it and click explore. find the file labled drivers and install them first than install the program hope this helps.
Jun 29, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Sometimes power comes on and sometimes it does not.
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
Oct 30, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexcion lamda and a mixer
yes you can. simply take a 1/4 in cable from the main out of you mixer and plug it in through one of the line in inputs on the back.
then plug whatever you want to record in through the mixer
May 03, 2008 | Lexicon Lambda Usb Desktop Recording...
Lambda doesn't record, though it seems ready to go
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Jan 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
47 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
