Question about Canon PowerShot A460 Digital Camera
Battery's Hi, I was just wondering if my Canon A460 would work with rechargeble batteries. Thanks, please respond urgent.
  • Canon Master
  • 4,738 Answers
Yes, in fact highly recommend rechargeable NiMH batteries for your camera. Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jul 03, 2008
Why is my canon A460 lens barrel not retract and gives an error message?
Again, could be battery life - are you using high power re-chargeable batteries (2100 or 2500) ? in it
Jul 20, 2016 | Canon PowerShot A460 Digital Camera
Of canon powershot A460
The A460 uses standard AA batteries. If you choose to use rechargeable batteries, you must charge them outside the camera in a separate charger.
Jun 26, 2012 | Canon PowerShot A460 Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
My Canon A460 powershot will not turn on. Changed the batteries. Using NiMH AA.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 24, 2010 | Canon Cameras
Problem with my rechargeble battery with my Canon Powershot A540.
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Sep 09, 2009 | Canon PowerShot A540 Digital Camera
Canon A460 problem
I have a Canon A460 and the only red light I know of is the auto-focus light. If it's a low battery you'll see the indicator on the screen, not a light.
Aug 11, 2008 | Canon PowerShot A460 Digital Camera
Samsung D760
You can try with a higher battery v. gr. mAh 2100
Aug 09, 2008 | Samsung Cameras
PowerShot A460 Battery Problem
try 2500 miliamp (mAh) ni-mh batteries
Jun 08, 2008 | Canon PowerShot A460 Digital Camera
Canon powershot a460
I have a Canon A460 that does this every now and then. Usually if I removed the batteries and put them back in, it does the trick. If that doesn't work, and the camera will stay on, try resetting it. Click Menu> Tools and then scroll all the way to the last option Reset All. Good luck!
Oct 09, 2007 | Canon PowerShot A460 Digital Camera
Canon PowerShot A460 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
