Question about Toshiba Televison & Video
WE CAN NOT GET OUR TV GUIDE AFTER USING IT FOR OVER A YEAR THEN ALL IT SAID WAS NO LISTING THEN THERE WAS IT TAKES 24 HOURS TO UPDATE TV GUIDE AND THAT HAS BEEN A WEEK AGO.
  • Toshiba Master
  • 5,568 Answers
The guides are not produced by your set. They are transmitted and maintained by your service provider (cable or satellite).
You need to speak with them about it.
Posted on Jul 03, 2008
What is the most likely suspect component? tv is 7 yrs old and i dont have a service manual
your problem is most likely caused by failing capacitors in the Power Supply, Check for leaking,domed tops, or bulging capacitors, this type of fault can have other causes, post your Brand and Model for more specific help, or have a look at some of the many repair kits available here:
TV Repair Kits MBTV Electronics
Hi ,
Proscan TV's are usually built using Vestel manufactured Internal PCB Panels, have a look at the many repair kits aimed at these, using the boards part number to search, The Part Number itself can be found on a White, Red or Green Sticker, and will be 8 digits long starting with either 20 or 23, look here for more info:
http://www.mbtvelectronics.co.uk/how-to-find-your-part-number-pcb-number/vestel-help
Feb 12, 2016 | Televison & Video
Miele dishwwasher
the control timer is most likley sticking or bad.you can try to remove the timer and check for any burns on the timer.let me know
Jan 06, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
RCA F36715 36" TV received this tv used from a friend. we do not have original remote so we use a generic universal remote. tv works fine, but we cannot get the Guide Plus+ to work. we went through the...
You're cable company may have quit using TV Guide info from "TV Guide", because they want you to get their box for this info, or to save expense. It happened here in Michigan about a year ago. If you have local ABC, NBC, and PBS stations, you can get this info downloaded nightly through an external "over-the-air" antenna.-- assuming you're in the U.S.
May 05, 2010 | RCA F36715 36" TV
My Pioneer PDP-4280HD Plasma - Have never been able to get the TV Guide feature to work. Only some of the set up screens are shown in the manual. Can someone help? I see the feed of channels, which is...
My research into your set and its TV Guide feature brought up two points that may be relevant:
  1. It apparently takes about 24 hours for the guide to load up completely. This would make it difficult to get real-time info as to whether it was working or not.
  2. 'TV Guide' may not work will all providers, and may not work as providers switch to digital. Have you spoken to your provider about possible compatibility?
I hope that helps
______________________
Click here for a Pioneer PDP-4280HD manual.
Apr 17, 2010 | Pioneer PDP-4280HD 42 in. Plasma...
How long after a maytag side by side sat for a year should it take to get cold
with the compressor running 24 hours. Just like when you buy one from the store it takes 24 hours for it to stabalize with the settings set in mid range.
Apr 12, 2010 | Maytag MZD2766GES Side by Side...
I can't get the recorder to keep my guide.
There might be a TV Guide issue located in your area, since the transition to digital, TV Guide have been updating there broadcast frequency which is know been done by CBS. Have unit reset by holding down channel up and down button for 15 second on the unit itself until 12 flashes on display, then power on unit and setup TV Guide, then have unit off for 24 hours especially between 11pm to 6am for listing. If issue still exist contact Panasonic to have issue send to TV Guide.
Sep 28, 2009 | Panasonic DMR-E85H DVD Recorder
Comcast freezing up...NEED HELP NOW!!!
Possibly a bad remote? The cable box might also be defective. Call tech support.
Jun 29, 2009 | Televison & Video
Hi.. i have an archos gen 5.. for the 1st year i could record from the tv listing for free. now that year is up and i can't seem to find out how i can get the tv listing to upgrade. so i can start...
Go to www.archos.com
My Account - and logon
Manage Products
Product Services
Scroll down to TV Program Guide available for owners of DVR Station Gen 5 and press Update
That will take you to the TVTV website where you can pay for another year's subscription. Currently around £14.
May 06, 2009 | Archos 605 WiFi Digital Media Player
50604 tv is trying to program channels how do i stop it ?
have a look here for your replacement mitsubishi remote:
http://www.electronicadventure.us/mitsubishi.htm
regards
Nov 26, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Guide Plus
Called the cable company..they said they don't block the signal. sooooo..
first..i unplugged the tv from the power source, and unplugged the cable from the wall. left both off for an hour, and reconnected power and cable.
entered the guide set up...changed the zip code from the area where i actually live to the zip code of the cable provider for my area. here on maui, there is only one provider.
used the editor in guide plus to turn on and off the channel line-up according to the published channels listed in my area tv guide.
24 hours later...voila..!! it WORKS..!! good luck..!!
Oct 16, 2008 | RCA G36705 36" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
