Spill on laptop..how do I clean
Toshiba Satellite A85-S107. Spilled sticky drink onto laptop. Everything works, but keys sticking. How do I disassemble to clean? Also, running spill on screen. Can screen be cleaned. Thanks for any help. I spill liquid into the keys of my laptop at thattime it shut off, however the next day it began to work again, but the key pad does not work. Please tell me what can i do?
  • pdpwp33 Dec 07, 2008
    My Ex wife just called me with a spill problem and I'm not sure what or how to help. Its her work laptop an IBM T series. Anyway she was in other room when she heard a loud noise and by the time she got to noise she found my daughter Amanda's dog peeing into keyboard !!!! Please e-mail with any solutions at pdpwp33@yahoo.com.
    She did turn it over as soon as she got to it then vacumed it the best she could. It did shut-off right away as pee hit it she said.....
    Please help if you or anyoine can,
    Thanks
    Peter
    Sergeant:
  • 313 Answers
Ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
Posted on Jul 03, 2008
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
On my toshiba satellite a85-s107 have a loose connection at the power plug in so power is constantly going on and off this is at the laptop plug in
The only way to deal with this is take laptop apart to access the motherboard and resolder the plug points to firm up the connection. There is no other way to address this.
Mar 07, 2012 | Toshiba Satellite A85-S107 PC Notebook
I would like to restore my Toshiba Satellite laptop A85 to original state. Can I do this without the disks. I have backed up all of my information and want to start over.
It depends. Some laptop computers have a usually-hidden "recovery" partition on the disk-drive.
Reboot the computer, and look for a "start recovery" option as the first page of text on the computer-screen. Press the specified key to access that "recovery" partition.
Or, some Toshiba computers have a utility to *CREATE* a set of system-recovery CDs, by burning the necessary files onto CD/DVD-recordable disks. Run that utility.
Jan 02, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite a85-s107 disc drive not working. drive opens takes cds and acts like its reading them but the program never opens
google search a downloaded program called CD BEGONE...run it..reboot pc.
if that does not cure problem....buy a replacement drivefrom ebay
Sep 15, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite a85-S107 the volume control wheel on the computer does not turn the volume all the way down. I can still control it through windows. Help!
maybe your driver is not working well http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm go to this site you can find drivers of toshiba there. reinstall some of your not compatible drivers.
Aug 06, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba a85-s107 satellite laptop - does not power on
Remove the battery and reinstall the battery. It should reboot
Apr 09, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
752 people viewed this question
David Payne
David Payne
