The belt is not on the motor shaft. Remove the head from the motor unit. With the belt centered on the brushroll, turn the belt lifter a full 3/4 turn counterclockwise to stretch the belt up onto the belt lifter finger. ( Look through the back to be sure the belt is streched into a loop over the finger.) Plce the head back on the motor unit and latch it in place, then turn the belt lifter fully clockwise to drop the belt onto the motor shaft. Be sure the brushroll is correctly installed in the head. Setting # 1 should face the floor.
This help the most. I borrowed my step-father's kirby. I took the head off to use the attachments and then could not get the head back on where the belt would go on the motor shaft. I found a users manual online that told me how to do it. I was doing it exactly like it said and it still did not work. They did not say anything about stretching the belt in the oposite direction and then turn it to the belt on position. I was excited about putting it on so I can use it thank you very much.
