Question about Gateway Computers & Internet
I would like to know how to lock the computer so the little ones cannot turn it on without an adult.I go to the lock button but you can still turn it on .Do I have to put in a pass word?
    Problem Solver:
  • 17 Answers
As I shooo my 3 year old away from the tower's power button I'll answer this one! YES! password the system, you can make it simple as 1 or 2 digits to make it simple to log in. Also, what i do is set the power button not to shut down the PC if it is pushed. (Start, Shut Down is used) this is how I did it: Right click on desktop and click "Properties" click on "Screen Saver" Click on "Power" then click on "Advanced" as you will see there is the setting to change this.
Hope this helps
Posted on Jul 03, 2008
The power button completely broke off my emachine T3090 desktop. How can I get computer to start-up without this button?
You should be able To just reach in there and press it anyways. It depends what emachines uses, but normally it is a little white plastic thing that the button pushes, because it does nothing itself.
*If this answer helped you, please rate it 4 thumbs up!*
May 15, 2011 | E-Machines eMachines Desktop PC
Tip
How Often should i clean my pc?
Where is computer located? In a home environment In a clean office environment In construction / industry environment In school environment Computer environment Have cat / dog in same building as computer Smoke in same building as computer Smoke next to computer Computer is on floor Room that the computer is in has carpet Eat and/or drink by computer Who uses it? Adult (18 and older) Young adults (ages 10-18) use computer Pre-teen (younger than 10) use computer More than one person uses computer
Based off what has been checked above you should be cleaning your computer every months.
on Mar 13, 2010 | Computers & Internet
I have an emachines desktop computer and some how 2 little thin wires came out from the button where you turn on the computer. I am not sure where those wires go but aparently they are really important...
The power button connects onto the motherboard with a jumper. One end of those cables probably go to the button the other end should connect to the motherboard where it says pwr with a few little pins.
Feb 11, 2011 | E-Machines eMachines Desktop PC
My caps wont turn off
Try this. Press: Start>Accessories>Accessibility>On Screen keyboard. Try turning it off from there. If that doesn't work:
1. Choose Start'Settings'Control Panel and double-click Regional and Language Options.
2. In the Languages tab, click the Details button.
3. In the Settings tab, you should see a button called Key Settings. It may be grayed out. If it is, click the Add button and add another keyboard layout (it doesn't matter which one). Press OK.
4. Back in the Settings tab, click to make sure your original keyboard is highlighted and press the Key Settings button.
5. Now under To turn off Caps Lock, click the radio button next to Press the Shift key. Click OK.
6. Click OK twice more to exit the other two dialog boxes.
Jan 13, 2011 | HP Computers & Internet
I have emachine ET 1641-02w check the power supply and its check out ok but computer wont turn on
I will assume that you have not messed with anything and it just stopped working. So try these steps:
1) Check the power plug, make sure it is plugged into the wall and also into the back of the computer.
2) Check to see that the switch is "On" on the back of the power supply if there is one.
3) Take the case off and look at the power button, try to press it without the case on, perhaps the power button is broken. If that doesnt work try and see if the little wires on the back of the power button are connect and bot pushed off.
4) Check the cables to the power supply, ensure they are connected to the motherboard and not disconnnected.
5) If all of the above do not work, take a power supply from another system and plug it in to *********** board, see if the computer boots normaly then. If that works you can assume the power supply is shot.
Let me know if there is anything else.
-Paul
Jul 12, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
Please help
If you want to do this without a router (people actually do this? I like the hardware firewall) then you would need to have a second network card in the computer connecting to the modem (so one card connects to the modem and one to the second computer) and have the internet sharing capability turned on. I've never set it up so I'm afraid I can't be much more help, I just know a little bit about it.
Good luck :)
Dec 09, 2008 | Computers & Internet
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
It wornt start up
Mandy can you be a little more precise what won't start up? your on the Internet, something started up.
Nov 01, 2008 | Computers & Internet
I just bought a docking station for my Dell laptop computer. How do I hook it up so I can keep the top closed and use my desk top monitor? I want to be able to turn on the laptop without opening the lid.
Well.. you'd still have to open the lid to turn it on, right? (because you didn't mention the model of your laptop, I don't know where the power button actually *is*)
You want to close it while it's on, without it hibernating or going to sleep...
Go to your control panel, then into power or power management (depending on your Windows version, because you didn't mention it)
Then have a look under the "advanced" tab where it asks "when I close the lid of my computer". Set that to "do nothing".
Now when you close the lid, the laptop screen should turn off, but the PC should keep running. I'm not sure if that will still turn your external monitor off though.
I think that is your best solution, other than hacking off the little button that senses when the lid is closed. =-]
Aug 23, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
