Question about ViewSonic VG900 19" Flat Panel LCD Monitor
Resolution problem of viewsonic VG2021m as the second monitor of thinkpad t61p
The viewsonic vg2021m can only have 1024*900 when connected to thinkpad t61p as the second monitor
Go into the NVidia control panel, create a custom resolution (for the ViewSonic VG2021m, you want 1400x1050, 60Hz), and test it.  When the test asks you if it looks ok and you click "yes", it *still* is not activated-- it is simply added as one of the resolutions available for the monitor, and goes back to the same setting you had before... so it looks like it didn't work.  But then, if you go under "Change resolution", you'll see your new setting is available there.  Choose it, and you are good.
It's working for me, on my T61.
Dan
Posted on Jun 19, 2009
Out of Range HFreq 91 KHZ and V Freq 85 HZ How do I fix?
Lower your resolution step by step until it is in range.
May 27, 2011 | ViewSonic Graphic VG2021m LCD Monitor
How do i get a sharper picture please its a viewsonic vg2021m had it given to me i dont know what to do thanks
check the nature resolution of this LCD. It is 1400 x 1050 resolution.
You need the LCD driver from viewsonic web site. Go download and install.
Make sure your graphics card driver is latest one so can auto detect the LCD res. as well.
Good day.
Jan 03, 2011 | ViewSonic Graphic VG2021m LCD Monitor
Hello, I ordered a Viewsonic VG2021m monitor a while ago, and recently, the monitor shows nothing but black when plugged in. All cables on it have been checked, and my computer acknowledges it is there,...
This is 2006 model year, more likely to have bad caps problem in the power supply, look for caps with leaking/bulging tops first, also look to see if you do have 12~18vdc feeding the inverter circuits.
This your power supply/backlight inverter board:
http://www.shopjimmy.com/power-supply-unit-dac-12m033-af-from-viewsonic-vg2021m.htm
Learn about bad caps and failed monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | ViewSonic VG2021m LCD Monitor
Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
May 24, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
I have a Viewsonic VG2021m.. I think the speaker (s) is not working. There is no sound coming from my monitor.
your monitor have 4 buttons in the right down. the first is for turn on or off the speakers ;)
Apr 28, 2010 | ViewSonic VG2021m LCD Monitor
Viewsonic vg2021m monitor goes blank.
the probelm u are having mostlickly the backlight is out on your monitrer. thy CAN be replaced but with all the time it takes and money to do them i sugjest just getting a new moniter.
Dec 31, 2009 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonic VG2021m monitor without installation software
try using the FN "function key" and you should have a button at the top that looks like and LCD press it while holding the FN button
Dec 16, 2009 | ViewSonic VG2021m LCD Monitor
Viewsonic monitor VG2021m won't awaken
I understand the vg2021m has a 3 year warranty. Phone number for Product Support is (800) 688-6688. Give 'em a call and see if they won't fix it for free or some nominal charge. (OK! So this is the cowards way out.)
Orval
Oct 05, 2008 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonic VG900 19" Flat Panel LCD Monitor Logo
418 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
