Question about Singer 3820 Mechanical Sewing Machine
The bottom part of mystitch looks like a bird nest
  • 4 Answers
HI Leaann! I have solution that may help!
I inherited an old Singer 457 (from 1964!) from my Grandmother. I used it a few times with success but then I too started to get birdsnests on the bottom of my work or knots in the area the houses the bobbin.
After much fiddling, using different bobbins and spools of thread, tension and what-not, I discovered that the it was one particular plastic BOBBIN giving me trouble! Although it appeared the same size and width, there is something about this bobbin that will mess up the machine (and within 16 stitches).
I just tossed the thing and have been trouble free ever since!
Try changing out your bobbin, the problem may resolve itself.
Posted on Jan 27, 2009
Hi I am having problem with my sewing machine. Thread gets all tangled up on the bottom of the fabric... My husband is very smart about machine and needs just suggestions from you.
That is called bird nesting or thread nesting and usually results from: mis-threading, thread not seated fully in the upper tension disk, or upper tension too loose. (Mis-threading may not be a user error--sometimes the thread will "jump" out of thread guide or the take-up lever.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low number and retest your machine. The upper tension will probably need some tweaking for your particular machine, but the mid-point is a good place to start.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Tutorials Urban Threads Unique and Awesome Embroidery Designs
Jan 12, 2017 | Sewing Machines
Have lots of thread on the under side of fabric
Thread nesting or bird nesting resulting usually from: mis-threading, upper thread not seated completely in the tension disk, upper thread tension too loose. HINT: ALWAYS raise the presser foot when threading the upper thread.
Sewing Machine Thread Bunching Up Here Why
Jan 05, 2017 | Sewing Machines
Stiches at the bottom come out like a rats nest not sewing right?
Generally, thread issues that appear under the fabric are the result of an upper thread problem. What you describe sounds like bird nesting or thread nesting and are usually a result of: mis-threading, thread not being fully seated in the tension disk, and/or upper tension too loose.
Remove the upper thread. ALWAYS raise the presser foot. Rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low numbers (although this will probably need to be tweaked for your particular machine). Retest your machine. Adjust the upper tension until both threads meet in the middle of your fabric.
FWIW, mis-threading may not be your mistake. I have an older machine that the take-up lever is open at the top. Sometimes, usually when sewing fast, the thread will literally "jump" out of that take-up lever and...instant thread mess... So, if this sort of thing occurs frequently with your machine, try to narrow where the problem originates. With my machine, I "manufactured" a method of closing the opening in the take-up lever. Voila! No more jumping thread!
Troubleshooting Thread Nesting Sew Toot
Dec 31, 2016 | Sewing Machines
I'm getting a 'bird's nest' of thread on the bottom of my stitching...Why
needle thread tension is too light
increase that tension setting
Nov 19, 2016 | Sewing Machines
Phaff 1472 stitches are bunching up underneath
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
Nov 17, 2016 | PfaFF Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Bobbin trouble
possibly not enough upper tension .
Oct 17, 2015 | Sewing Machines
Bobbin tension on a huquvarna
Birds nests on the bottom is NOT the bobbin tension. First make sure you are properly threading your Husky with the presser foot in the UP position. then to a test seam on a scrap of the same fabric. If it still nests.... tighten the top tension. and test again. Keep tightening the top tension and testing until you get it resolved.
Oct 12, 2012 | Husqvarna Viking 1
Singer 3820 Mechanical Sewing Machine Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
