How to remove cover on a dell dimension 2400 - Computers & Internet
    Problem Solver:
  • 17 Answers
Slide the plastic "L" in the back down (facing the back of tower it will be mid right) while holding the "L" down slide the side cover towards the back (facing the back of tower it will be the right side cover) It may take a little persuading!
Posted on Jul 03, 2008
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
JAN_yuanjia
  • 470 Answers
SOURCE: How to open dell 4300 dimension cover
to open the case, which lies open like a book after you place it on its side. Closing it was also tricky, as cables got hung up on internal components.
This machine is middle-of-the-pack by most performance measures. Equipped with a 1.5-GHz Pentium 4 processor and 256MB of SDRAM, it posted a score of 94 on our PC WorldBench 4 tests, about what we've seen from other 1.5-GHz machines running Windows XP Home. The 17-inch Dell M781S monitor displayed excellent 12-point text at 1024 by 768 resolution. Our color photo of a group of children looked sharply focused, although its colors could have been more saturated. The Harman/Kardon HK695 audio system's two slender, champagne-glass-shaped satellite speakers were surprisingly powerful for their size, but the black subwoofer sounded somewhat weak. And disappointingly, game play broke down at a resolution of 1280 by 1024 with 32-bit color in our Quake III and Unreal Tournament game tests. Our judges awarded only middling scores for image quality in both games at 1024-by-768 resolution.
While not a powerhouse or a high-end multimedia center, the Dimension 4300 remains a reasonably priced all-around family system.
Posted on Feb 13, 2009
proton77
  • 1183 Answers
SOURCE: How to remove the hard drive from my dell
Take the print out of the removal intructions from the link below
http://tinyurl.com/9x92t
Thanks
Proton
Posted on Feb 23, 2009
  • 9 Answers
SOURCE: How to remove tower cover...
There are going to be a few small screws on the the back right side (if you are looking at the back of the tower. Remove the the screws from along the edge of the side ( you may have to loosen both sides ) and the case slides towards you then lifts off. If it doesn't budge use a flat head screwdriver to pry in between the cover and tower case and gently slide it towards you. Trust mr it won't break cause it's metal and if it bends you can use pliers to bend it back to shape. Hope the info helps GOD Bless You.
Posted on Mar 21, 2009
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
Remove Dell Dimension 2400 Cover - I have been to the Dell site and read the documentation. But opening the cover seems to require two people - or three hands! Are there any tricks of the trade? Thanks!
This is a rather simple case face to remove.
Remove the side cover and place the unit on its side. hold the bottom of the face with 1 hand and pull gently while popping the 4 clips inside the case on the bottom end.
After you have done this there should be 1 on the side you can pop then there is a metal flexible peice at the top, pressing that down will relieve the top clip.
Place the case upright while holding the face out, after this the case will pop off to the opposite side of the case that the case opening is on.
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
Trying to put new ram in Dimension 2400, but don't know how to remove cover.
Go to page 49 of the following manual and it will show you how to take off the cover to access the inside of the tower.
If I have helped you, please take the time to rate my help as it allows me to help others.
Regards
http://support.dell.com/support/edocs/systems/dim2400/en/F75560LRs.pdf
Aug 06, 2009 | Dell Dimension 2400 PC Desktop
HOW DO I REMOVE COVER OF 2400 TOWER,INSTALLING 80G HARD DRIVE
Here’s a link to the service manual for 2400: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 2400 PC Desktop
Upgrading Memory from 256 to 1GB
You shouldn't have to remove it, but if the system won't boot after try reversing the slot, and if that doesn't work take out the 256.
Feb 03, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
1,002 people viewed this question
David Payne
David Payne
