Question about Refrigerators
How do you stop ice dripping
After istalling the icemaker, we turned the water on and water is dripping from the maker into the ice pan. Also what controls how much water goes into the ice maker.
  • 61 Answers
There is a water valve ( usually behind fridge in-line with tubing for water ), the valve is activated and releases water to fill cube tray. Does yours continue to fill or is it just overfilling a little too much and then stopping? You could try doing a search for schematics or diagrams for your make/model on Google for more info on how to adjust if it can be adjusted. Good Luck. If you are only getting a little bit of water in the ice pan and its just an annoyance, you could look for a plastic grid material that you could cut to fit into bottom of pan to keep ice from sitting in water. Then just empty water every so often.
Posted on Jul 03, 2008
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
I have an older fridge with the ice maker in the freezer, just dumps into tray below. Anywho, water leaks from the ice make everytime it fills into the pan below, making one giant junk of ice. Please...
you have to determine if its the icemaker mold that has a crack and therefore leaks, or if you water valve solenoid is not closing compeletly at the end of the cycle. to check this, turn the water supply off to the refrigerator, then lift the arm up to turn the icemaker off. wait 3-6 hours, in case it JUST cycled, turn the icemaker back on, and it should dump one last set of ice cubes. slowly pour 4-8 oz of water into the icemaker with a measuring cup. do you see that same drip? if you do, replace your icemaker, if you dont, replace your water valve.
Mar 17, 2010 | Refrigerators
We are getting an overflow of water in the pan in the bottom of the refrig. What causes that and can the pan be removed to empty?
This may sound strange, but the cause of your problem may be your icemaker. The fill tube may be leaking before it gets to the ice maker and causing the pan uner the fridge to fill up too much. try turning your ice maker off for a few days and see if the issue stops. Or you can see if the tube is loose or iced up. If it is iced up, you may have a bad water valve. If you need more assistance, let me know. Hope this helps!
Dec 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Icemaker problem with Samsung RB215BssB refrigerator
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it can freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Refrigerators
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Whirlpool ET1CHMXK09 top freezer with icemaker: Has leaked almost daily. At installation, Lowe's employees had trouble with gasket provided in the icemaker installation kit and had to get something else...
I decided maybe we were fixated on the ice maker because it's the obvious culprit/source of water input. However, thought more broadly and then fixated on the frost-free aspect and the drip pan. In case ice was building up and defrosting within the refrigerator back, even though the pan was bone dry, I removed 1/3 of the freezer contents to another freezer to maximize air circulation in the freezer compartment. At the 24-hr mark, after this change, there was an approximate 2 tablespoon drip downstairs so I don't consider the problem fixed necessarily. The next 24-hour period is late this afternoon. However, I still empty the ice cube bin so it will never stop making ice in case it is the pressure of the water in the line which, when no ice is made because the bin is full, it leaks where the line comes into the back of the fridge, but out of sight, until it pools on the floor enough to run through to the floor below, downstairs.
Thank you for contacting me. I'm telling others about your site.
May 04, 2009 | Refrigerators
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
