Question about Kitchen Ranges
Westinghouse gas stove virtuoso The stove continously keeping sparking when you turn on the elctrical switch conneting to the gas stove
  • Anonymous Apr 12, 2009
    westinghouse gas stove virtuoso
  • Anonymous Mar 29, 2014
    turns red on low setting
    Brigadier General:
  • 6,966 Answers
Hi again,
Any development(s) with your Electrolux GHL795SLP?
Good luck and kind regards.
Posted on Jul 03, 2008
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
Kenmore gas 4burner cooktop model#229c44330p001-0 when its off the pilot keeps clicking(sparking) every 5-7secondstcarthen@
Hi
There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes. The next thing to check for are theignition switchesunder the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a badsparkmodule which should be replaced as sometimes cleaning can get moisture into the surface switches; try drying them with a hair dryer to see if this will help. Hope this helps...please post back for further assistance.
Daniel
Jun 21, 2011 | Kenmore Kitchen Ranges
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
All of a sudden, none of the 4 elctric starter on the burners work on my maytag gas stove
sounds like the spark module is defective. have a technician replace it.
Sep 13, 2008 | Maytag Kitchen Ranges
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Kitchen Ranges Logo
215 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
