Question about HP Computers & Internet
Computer crashed / upgraded to XP / don't have disc to reinstall
    Genius:
  • 2,785 Answers
Without cd you cant install your os
Posted on Jul 03, 2008
Dc7100sff multiple controller not working ?
Reinstall windows and use original HP drivers
Aug 15, 2015 | HP dc7100 SFF PC Desktop
Dell 6400 hangs and then crashes
Try replacing or upgrading your RAM it sounds like your PC is overworked and the bsod is probably a result of data loss due to low ram
Aug 18, 2008 | Computers & Internet
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
I have upgraded from Norton internet security suite 2005 to the 2008 edition. My computer keeps freezing up and crashing. I have uninstalled and re-installed the program to no avail. Norton also keeps...
Trojans can be tough to get rid of, the best solution is to reinstall Windows xp, then try installing norton again. Reinstalling windows will rid your computer of whatever program or cookie that contains the trojan. Then norton should take over and keep these forms of malware at bay.
May 31, 2008 | Computers & Internet
Reactivation of office xp after winxp crash
you need to reinstall also your microsoft office in order to reactivate. if the reinstallation was only repair it won't damage your microsoft office
Dec 19, 2007 | Microsoft Office Xp Professional Full...
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
