Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissel vacuum cleaner
Bought a Bissel about three months ago, and I HATE IT!!!! too heavy, awkward to use the cord is attached way down at the bottom so I have to hold it in place. The whole machine is very dusty after I clean and remove the dust holder, extra dust falls out, its a mess and I wish I had never bought it. However can't afford to buy another so I am venting!! so disappointed in this machine.
raybeanes@hotmail.com phone number....406-293-3547
    President:
  • 1,673 Answers
That is the problem with a bagless, but if you keep the filters clean it won't be quite as dusty.
Posted on Nov 29, 2008
Hose in DYSON too tight and hard to pull out
The problem is not a twisted hose. The hose itself is way too stiff. It pulls the vacuum around instead of expanding to reach. I hate this hose and it's too bad, because the vacuum works well, but trying to use the hose attachment it futile because it just doesn't stretch out unless the vacuum is pinned up against something to keep it from rolling and tipping over.
Nov 24, 2012 | Dyson DC25 Vacuum
I bought a bissel quicksteamer powerbrush multisurface 2 weeks ago used it once. Now it will not **** up the water it sprays fine but won't **** up
if you bought ot new.its under warantry, take it back were you bought it, you are covered under the sale of goods act the, shop has to fix the problem
Aug 16, 2011 | Bissell Vacuums
Miele Red Star model S314. Cord reel is stuck. About three feet of cord is out. The rest of cord is jammed inside machine? How do I get to where the cord reel is?
It is actually simple when I tell you, Here we go...
First, open the lid and take the bag, and hepa filter out of the machine.
With a slot screwdriver, pry the hinges of the bag door out a little and take the bag door off.
You should see one screw holding the black black panel, remove that. When that is out, you can pull the black panel off. It will give a little resistance to you, do not be afraid of breaking it, it will come off.
Next you will see 4 or 5 screws down the holes there, remove all of them and the final remaining red piece will come off. When you pull this off, it will have both the cord rewinder and the motor assembly attached to it. It will be heavy becasue of the motor. Before you pull out the cord rewinder, just have a look at it closely and you may be able to just fix it without removing anything else.
good luck with it.
Nov 05, 2010 | Miele Red Star Bagged Canister Vacuum
HEATS UP BUT NO STEAM?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
n
Jul 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Water flowing out bottom of steamcleaner
It sounds like one of the internal tubes is loose or has a leak. You'll need to open up the black plate (the plate where you place the water tank on top of). Inside there, you'll be able to see all the tubes and hopefully track down which one is leaking or loose. Some of the tubes have clips to hold them in place. Perhaps one of those came loose.
Jan 26, 2010 | Bissell 9200 Upright Vacuum
Proheat2x carpet cleaner
Sometimes we will get a lemon even in small equiptment but I would encourge you to not allow call again but email tech. support too see if you get the right person that will see you thru to the end.
Dec 01, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel proheat won't spray from bottom or attachment
I had the same problem. After 3 weeks of seals belts pump etc. I was ready to give up.
The problem with mine as I suspect with others is the seal on the water tank.
The bottom plastic connector is not high enough to allow the water to flow to the pump.
My solution was to raise the bottom connector 3/16 of an inch.
I did this with a piece of plastic cut like a flat washer or auto gasket material could be used.
The connector must be removed from the bottom by pressing on the tabs. Hope this helps.
Jan 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Jul 09, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
