Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire washing macine ATF6000ES1 error code E47
How do I get to the front door lock? Thanks!
Hi I have the same problem, Error Code 47. I went to the support page and only found manuals and the tech data sheet. Which one shows you how to get to the front door lock? Thank you
Posted on Jan 02, 2010
Test door lock ohms, if good faulty control board
Posted on Apr 02, 2012
  • 876 Answers
Go to www.frigidaire.com/support .enter you model number. you will get a list of manuals available for free download. There is tech Data manual and several others, normally.
These are in PDF format, so if you do not have acrobat reader, you need to go to www.adobe.com/acrobat and down load and install this free proggy.
When you download the manuals just save them to your desktop and youll be able to open and read them. On the left column you cill see a little stack that represents the pages of the manual.
Good Luck
Posted on Aug 13, 2008
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
What corrective action for e47 code?
Hello. I need the model number to help you accurately but I'll assume you have a Frigidaire washer. If so, then the E47 code is telling you that the main board thinks the door is open on spin. Go to this web address and it will tell you how to check the electric door lock mech. http://forum.partsdr.com/showthread.php?1-Frigidaire-Washer-E47-Error-Code. If you *don't* have a Frigidaire unit, please post a comment with the brand/model number so I can give you exact information. Thanks!
Sep 11, 2015 | Washing Machines
LTF2940ES E47 code repair
The E47 error code is usually an indication of a failed door lock/latch. To verify this, you will need to ohm out the PTC on the door lock. If the door lock does not ohm out correctly, then it will need to be replaced.
How to test the door latch on your washer
Nov 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
No spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Oct 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
E47 error
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Jun 28, 2008 | Frigidaire ATF6000ES Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
760 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
