Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Door adjustment. one side of door is taller than the other.
    Novelist:
  • 161 Answers
There are usually nylon washers on the bottom hinge pin. Last time the doors were removed one was probably lost. On a side by side or french door model the washers should be in the same place on each side. There is usually one or two on the bottom and at least one on top.
Posted on Jul 03, 2008
Adjusting doors to stay closed
It is not a matter of adjusting the doors. It is a matter of adjusting the legs so that the front legs are taller than the back. This causes the entire refrigerator to tilt toward the back, which is what makes the doors close by themselves. Your installer should have done this for you, as it differs between locations. It takes at least 2 people to do this: one person tilts the refrigerator back by pushing on the front of the freezer door, and the other person carefully rotates the front legs of the refrigerator until they lengthen about 1/2 inch - each! You might have to slide the whole refrigerator forward to give you some space behind it to allow tilting. Don't adjust the rear legs - not needed unless someone has unthreaded them in error, or for some unknown reason.
Oct 21, 2012 | Frigidaire FRT21P5A Top Freezer...
Saging door
You should be able to adjust the door hinges very similar to a normal household door. You may have to unscrew the hinge and reinsert. This would definitely involve two people.
Sep 05, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    Maytag Model MSD2454GRW side by side - the refrig door is not sealing tight about halfway down the door. Is there a adjustment I can make to help to door seal properly?
    Check to be sure the frig is sitting level. You should have leveling adjustment on each side below the doors and behind the grille. Also, on the bottom door hinge (usually fridge side) should be an adjustment to raise or lower the door to align the doors. After that if you simply have a deformed seal you can try carefully heating the seal with a hair dryer to soften it and should smooth out the wrinkles. Be careful not to over heat the seal. Good Luck
    Mar 12, 2011 | Maytag MSD2454G Side by Side Refrigerator
    Refrig door not closing properly, needs a push,
    DOOR IS NEEDING HINGE ADJUSTMENT. LOOSEN SCREWS IN HINGE, ADJUST DOOR TO ALIGN WITH SEALS AND TIGHTEN SCREWS TO RE-ADJUST.
    Feb 20, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Our side by side freezer door opens slightly
    That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
    Jan 03, 2010 | GE Refrigerators
    Side by side freezer door pops open
    This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
    Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
    How to adjust fridge and freezer doors on Kelvinator C520 Litre
    how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
    Apr 04, 2009 | Refrigerators
    GE Side by Side Fridge Door Adjustment
    Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
    Jul 02, 2008 | GE Refrigerators
    Door adjustment
    Move the left side leveling leg down (counter clockwise) and this will raise up the left side of the fridge also raising the door.  Let me know if this helps.
    Oct 13, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
    LG LFX25960ST Stainless Steel French Door Refrigerator Logo
    153 people viewed this question
    Top LG Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
