Question about Refrigerators
My freezer door seal doesn't "suction" anymore. i have ice build up.
  • kshaw88 Jul 03, 2008
    the seal is the issue - i found a gap and i dont' feel that suction when i open it. easy to replace the seal?
  • 481 Answers
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 02, 2008
  • Mike Durland
    Mike Durland Jul 04, 2008
    there is a trick to changing the door seal. when you buy it is folded up and wrinkled.
    • if it is a sunny day you can unfold the door seal and lay it out on the hood of a car and the heat from the sun will soften up the material and the wrinkles will go away. if it is cold outside or raining then use a haIrdryer to heat the door seal as you have it laid out in its rectangular shape.
    • once you have the door seal relaxed and ready to put on then take the door off the refrigerator (never try to put the door seal on while the door is still hanging).
    • lay the door on a large flat surface like a table or floor
    • the door seal should either be held in by a groove or secured by 1/4" hex screws
    • loosen all the screws (don't take them out)
    • take off the old gasket
    • fit the new gasket around the door just the way you want it.
    • then while the door is still laying flat tighten the screws starting with the center screws on each side of the door.
    • then put the door back on and your done.
    let me know if you need more help.
    Mike
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
The frost free freezer has started to form ice
First point of investigation, is to check the door seal. Sometimes new seals get stuck-suction and when opened and shut possibly cause a small tear, lubricate very gently with Vaseline, this will enable the seal to firstly seal properly and secondly not put undue pressure due to suction on new door seals.
If that does not resolve it then have a technician check the thermostat.
Mar 04, 2015 | Frost Refrigerators
I have a Sears Coldspot chest freezer Model #1869. The door doesn't seal properly and ice builds up within the door and the seal becomes even worse. The freezer itself works fine.
A precut seal will be expensive so please don't expect the price to be reasonable should you find one. Sears uses a longer number to list model numbers like 312.215478 as an example. Where can I find my model number? Let me know if you have questions, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Door jam icing up
door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
May 24, 2010 | True 72 cu. ft. / 2039 liter Commercial...
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice maker hanges up ice forms on blades
Hi and welcome to FixYa. I am Kelly.
Usually when ice (teardrops) form on the sweep blades it can be caused by a couple of things.
1. A dirty freezer door seal
2. A torn freezer door seal
3. Separation in the freezer door.
4, Calcium build up on the sweep blades.
Give the door seal a serious look for dirt and tears.
If the door seal looks ok and is clean then...
Wash the icemaker sweep blades with a mixture of vinegar and water. Give the freezer door some attention with that same mixture. Oils from hands or food can prevent a good seal on the freezer door. Just make sure you clean the icemaker sweep blades FIrst...
Do not use a new scotch brite pad on the sweep blades. USE an OLD one.... scratches on sweep baldes invite condensation when the door is opened.
Make sure to toss the next few cycles of ice cubes.
Doing the above should stop the ice build up on the sweep blades unless you have folks or visitors in the home that love holding the freezer door open for longer than normal.
Thanks for using FixYa.
Kelly
Feb 09, 2010 | Refrigerators
Ice build-up in freezer door - in frost free freezer - no problem for 1st year.
It may be a symptom of air entering to the freezer, so the seal may have issues. Another possible cause if the ventilator in the freezer is not working anymore. It depends of the Fridge model number that you have.
Oct 05, 2009 | Kenmore Freezers
Sears Upright freezer-the door does not have the suction anymore
You may need the hinge adjusted or a new door gasket but you might first try putting a layer of vaseline on the gasket. If none of those things help the problem is probably other than the door seal.
Dec 05, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Refrigerators Logo
371 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
