Question about Whirlpool GD2SHGX Refrigerator
Water keeps dripping from spout .....................
Every time my kids get water from the fridge the water spout keep dripping water.I toggle with the spout and the water stops.Not sure if it's the hard water or a part is going bad.
thank you
  • 25 Answers
Usually bc water valve not completely closing . i wud replace it
Posted on Jul 03, 2008
The small hole at the back of fridge keeps icing over how do i stop this from happening?
I usually use very hot water alil at a time onto the hole drain spout, and I have a soft long flexable tube that I insert into the whole ( the condensator) to clean out the blockage and debris. can use coat hanger but be very careful as can damage the tube drain line. unplug the drain line from bottom of drip pan and place towel under it, u can also try to blow into the flexable tubing down towards the drip pan if its not solid
Feb 16, 2015 | Kenmore Refridgerator Air Flow Diffuser...
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ice machine fill tube keeps dripping
What is the model number?
Oct 28, 2012 | Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The water spout on the inside of the fridge is dripping and we cannot figure out how to disconnect it
you have a bad water valve,the valve isn't closing all the way and water is dripping through
Feb 20, 2011 | Amana Refrigerators
When i turn the spout water is dripping out from
There are "o" rings between the spout and the body of the faucet that are getting worn and causing the leak. You need to replace the "o" rings. Shut off the water supply (both hot and cold), remove the handle, and then the spout should slide off exposing the "o" rings. You can get replacements at the hardware store. Put some vaseline on the "o" rings when you reassemble the faucet to keep the "o" rings from curling up and moving out of place. Good Luck.
Oct 22, 2009 | Plumbing
I have a side by side fridge/ freezer bought new 5 yrs age and the water/ice dispenser keeps leaking water. I noticed the the lever in the dispenser area seems loose. what would cause this type of problem?
One of two thing. Either the flap is not closing all the way allowing condensation to build up and drip, or you have a seaping water valve allowing water to seep out of the water spout insde the door.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Whirlpool Refrigerators
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Jul 31, 2009 | Refrigerators
New fridge keeps dripping water from the
Behind the panel of the dispenser there is an adjustment screw to adjust the microw switch If this does not fix it then the valve needs replacing Thatis usaly located in the bottom of the freg
Jul 12, 2009 | Refrigerators
Water in fridge
Blocked drain channel at back of fridge, get a flexible cable tie of piece of flexible wire push down as far as will go this will resolve fault. Regards Advisor
Aug 20, 2007 | Frigidaire GLRT83TES Top Freezer...
Whirlpool GD2SHGX Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
